Help daily driver
Old Apr 14, 2010 | 08:39 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
I forgot to say: DONT USE ETHER any more with the GPs ciclyng.
Old Apr 14, 2010 | 08:40 PM
Hussler's Avatar
Hussler
Originally Posted by RÖENTGEEP
Let us know more about your truck. Any mod, chip, tuner, etc?
How old is your oil, and is the level right?
The starter is working fine?
BTW welcome to the forum.
x2 .. have you check your oil level?
Does the tach indicate any movement when cranking?
Do you have a stock truck or is it chipped as RÖENTGEEP asked?
Old Apr 14, 2010 | 08:41 PM
cowmilker08's Avatar
cowmilker08
Yes the one you can use the tire gauge on.
Old Apr 14, 2010 | 08:42 PM
FARM69's Avatar
FARM69
Thats a good point Hussler. My Dp-Tuner came unplugged one time while backing a trailer and an hour later I finally figured what happened...
Old Apr 14, 2010 | 08:45 PM
fordstaf's Avatar
fordstaf
He is checking the passenger side plug... BRB
Old Apr 14, 2010 | 08:48 PM
fordstaf's Avatar
fordstaf
truck is all stock no chip. what is a Dp-Tuner?
Old Apr 14, 2010 | 08:49 PM
cowmilker08
A Brand of Chip
Old Apr 14, 2010 | 08:51 PM
fordstaf's Avatar
fordstaf
the fuel pump... when you have the key on should it give pressure? it only gives pressure when cranking.
Old Apr 14, 2010 | 08:57 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Only when cranking, you shoud have at least 20 psi, ideally 45-75 psi.
Hussler's Avatar
Hussler
Previous question .. important, Does the tach indicate any movement when cranking?
Old Apr 14, 2010 | 08:59 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
X2, very important
fordstaf's Avatar
fordstaf
oh sorry, the tack does move. we replaced the cps and even got another one just in case it was a faulty one.
Old Apr 14, 2010 | 09:01 PM
  #28
fordstaf's Avatar
fordstaf
I will be right back, going to check how much pressure ... thank you all again for your imputs
Old Apr 14, 2010 | 09:04 PM
  #29
cowmilker08
Also did you check that plug on the side of the fuel bowl?
Old Apr 14, 2010 | 09:06 PM
  #30
Hussler's Avatar
Hussler
What ya all think guys, maybe HPOP level needs to be checked?
