Explorer door hinge R&R
Old Jan 28, 2003 | 01:33 PM
creede's Avatar
creede
Question Explorer door hinge R&R
I want to change the right front upper door hinge on a '92 Explorer. I have the part. My question has to do with the rivet. After it is cut out, is there enough clearance to insert the oblong nut on the replacement part? If anyone knows how to do this, please give me the step by step details after the rivet is removed.
Thanks for any help.
Old Jan 31, 2003 | 01:20 PM
Scot's Avatar
Scot
I replaced the lower hinge on a '94. Whole thing was ~$20 from Ford. Might consider that.
Old Jan 31, 2003 | 06:22 PM
4starcstms's Avatar
4starcstms
A new Hinge assembly, part Number F58Z1622800A 22.10
As for rebuilding the hinge, I am unsure if you are able to w/o alot of work. Replace time on my computer at work is showing roughly a Hour, but that's removing the door assembly. If you dont have power anything.. It isnt that involved, if you do...Nightmare. =)
Old Jan 31, 2003 | 08:14 PM
creede's Avatar
creede
Thanks for the reply.
I have the hinge. My question is about the one rivet that holds the hinge to the frame. I can chisel it off but not sure what to do next. After removing the glove box, there is a hole in the frame behind the rivet. There is insulation in front of where the rivet would be. I don't know if there is metal work in between. I have not broken through the insulation. I really wanted to know how the replacement was done before I started tearing things apart.
DoggedTired
Dec 4, 2016 07:49 PM
Scotty's 52 F3
May 2, 2016 01:17 AM
j7angus
Mar 12, 2012 02:25 PM
Fix
1947 and Older Ford Trucks
Aug 9, 2006 11:47 PM
Aztrainer
Jul 29, 2004 01:46 PM
