Gas Tank Help
Old Apr 13, 2010 | 01:18 PM
sasamsen's Avatar
sasamsen
Gas Tank Help
1978 F350 Trailer Special with 351M/4Speed 2x4
Side bed has gas doors for side tank and rear tank. There is nothing there when you open the side tank door. Rear door has gas tank that leaks real real bad if you fill it more than half way. Everything I have looked at so far doesn't specifically list an F350 Trailer Special for tanks. LMC lists their tanks for F150 & F250.
Are all the tanks interchangeable for all the models?
Anything specifically I should be looking for?
I'm new to Fords..
Thanks,
Scott
Old Apr 13, 2010 | 01:26 PM
thefordlane's Avatar
thefordlane
Here is a link for the rear gas tank. Hope this is what you were askin for.
Lane
Dorman 576-116 - Dorman Fuel Tanks - Overview - SummitRacing.com
Old Apr 13, 2010 | 02:50 PM
1Aauto's Avatar
1Aauto
Former Vendor
HI Scott,
Here's a link to our gas tank section if you would like to see what we have to offer.
Ford Truck Gas Tank
Old Apr 13, 2010 | 08:30 PM
sasamsen's Avatar
sasamsen
My biggest concern is if there is any difference in gas tanks for the trailer special package.
Old Apr 13, 2010 | 09:32 PM
lostinfords's Avatar
lostinfords
???? I have a trailer special crew cab 2wd f350 and if I recall the frame is narrower, like 34" instead of the 37" and the rear springs are the same as the cab/chassis or like the highboys..the 2 -1/4" vs. 3" wide rear springs..that bing the case the std. aft fuel tank won't work...check to see if yours is the same, does the aft tank look like this?
Old Apr 14, 2010 | 11:29 AM
sasamsen's Avatar
sasamsen
Just crawled out from under her a few minutes ago!
Springs are 2 1/4"
The shield that covers the tank is 26 3/4" So tank is approx. 25" wide
Inside frame is 28 1/4"
Old Apr 14, 2010 | 12:23 PM
lostinfords
[quote=sasamsen;8769573]Just crawled out from under her a few minutes ago!
Springs are 2 1/4"
that being the case you can't use the normal aft tank that is available by MOST distributors, if you are able to locate one..... verify their measurements w/ those of your existing tank..most distributors/manufacturers are selling the tanks for the 37" wide frames, not the 34" wide frames
Old Apr 14, 2010 | 03:32 PM
sasamsen's Avatar
sasamsen
Yeah, so far all I've been seeing is the standard size. That bronco site everyone links to on here has poly tanks that fit the long wheel base for the side mount. Maybe I should look into adding the side tank.
Old Apr 15, 2010 | 07:23 AM
lostinfords
There is a ceramic based gas tank sealer available which will seal your tank, I used it on a motorcycle tank w/ no problems and I bought it for my 4wd supercab front fuel tank, another fuel tank whiuch is not reproduced, but have not sealed it yet..
Old Apr 15, 2010 | 04:00 PM
sasamsen's Avatar
sasamsen
I'll try the sealer. Thanks for the help!
Old Apr 15, 2010 | 04:19 PM
pat67shorty's Avatar
pat67shorty
Worst comes to worse.. you could probably use a bronco II tank with some mods.
Old Apr 16, 2010 | 08:03 PM
sasamsen's Avatar
sasamsen
I ordered some of KBS Coatings products for the inside and outside of the tank. I'll post some before, during & after photos.
Old Apr 19, 2010 | 12:12 PM
sasamsen's Avatar
sasamsen
The plot thickens! I pulled the gas tank today and this is what I found! It's a poly tank that someone tried to fix at one time or another.
And this is what was holding it up....
Anybody recognize what this tank might be out of? It doesn't seem to be very big to me?
Old Apr 19, 2010 | 12:56 PM
ChaseTruck754's Avatar
ChaseTruck754
Looks like the stock 19 gal tank out of these trucks.
I pulled one out of a '73 Super Camper Special to run in the rear of my 74 crew cab highboy (narrow frame as well).
From what I have seen the aftermarket replacements are NOT available for these tanks. I haven't found a replacement sending unit either
BUT, I had a buddy loan me his sender from a replacement tank from a 37" wide frame truck and it looked pretty similar. Similar enough to grab one and modify or run it...
His is the shiny one of course, and the other MESS is what came out of the 73 tank I grabbed.
Old Apr 19, 2010 | 06:56 PM
sasamsen's Avatar
sasamsen
I was shocked to see it was a plastic tank. I didn't know they used plastic tanks back in the 70's. I guess I should have dropped it before I bought the sealer. I just bought a used tank & skid plate off ebay for it.
Here are pics of the sending unit from mine. I don't know how accurate it is? I could never go past half tank without gas pouring out. My gauge read a little below E when I dropped the tank. I siphoned another 2 to 2.5 gallons out of the tank after I dropped it.
