Injectors went great I would like to thank everyone!
Old 04-12-2010, 09:51 PM
powerstroker100's Avatar
powerstroker100
powerstroker100 is offline
Thumbs up Injectors went great I would like to thank everyone!
Hello my friends, I completed my injector replacement today, I also changed out oil and coolant used shell rotella t6 5w40 ford gold coolant and oem oil filter and I can honestly say WHAT A DIFFERENCE, I CANT BELIEVE I WAS MISSING OUT THE LAST FEW WEEKS WITH MY TRUCK RUNNING SO CRUDDY!! I would like to give a special thanks to Bismic, Cheezit and M-chan who helped me the most through my work but would also like to thank everyone who commented giving me tips here and there you guys were extremely helpful and I probably wouldnt of figured where to start without the help, I only drove the truck about 12 miles, I'm sure there is still a ton of air in the system, next on the to do list! is to remove that blue boot connection the large pipe to the turbo I found the slit in it today thats where my chirping noise is that pierces my ears, then after that is passenger and driver side glowplug harnesses and while I do that I want to replace all 8 glow plugs I hope this wont be a crazy chore but then after that I can start with the real upgrades!
Old 04-12-2010, 10:09 PM
cheezit's Avatar
cheezit
cheezit is offline
replaceing the glowplugs is not really neccary unless they are bad, very easy thing to test. all you need is a dvom and 10 min of time.
also please keep in mind you may have issues with extened crank times for aprox 100 miles do to air in the system
happy to help and glad all went well. just wondering how long did it take you.
Old 04-12-2010, 10:16 PM
powerstroker100
thanks for the info cheezit, the whole job took me about 10 hours split into two days
Old 04-12-2010, 10:25 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
I agree. I have only ever replaced ONE glow plug on a 6.0L out of the tons of them that I've wrenched on so far. Like already stated, if you have glow plug or glow plug system issues, it WILL throw the Check Engine light on. And yes, any time you "open up" the high pressure oil system in any way, extended crank times are to be expected until the high pressure oil system primes up.
Old 04-12-2010, 10:28 PM
bismic's Avatar
bismic
bismic is online now
Received 2,510 Likes on 1,745 Posts
Congratulations - glad it went well for you!
It is great to know you can do this work and save some big bucks!!
Old 04-13-2010, 10:54 PM
powerstroker100
yeah saved hundreds in labor which is awesome tried to do intercooler boots today to get rid of that hiss but no luck hopefully that money I saved wont need to go towards something expensive
BryanStein
09-23-2015 10:54 PM
hesterb001
02-22-2015 07:26 AM
steventothemax
02-06-2012 04:22 PM
y0manda
05-09-2010 12:57 PM
89nolaf250
45
12-08-2009 01:59 PM
Quick Reply: Injectors went great I would like to thank everyone!
