Sponsored by: Real Truck
Domelight problem
Old Apr 12, 2010 | 10:15 AM
OHSBB45's Avatar
OHSBB45
Domelight problem
I have an 07 F250, 6 spd manual. The domelight does not come on when I open the door. I know somewhere, something is not telling something the door is open or closed. How can I fix this?
Old Apr 12, 2010 | 11:26 AM
johnwill's Avatar
johnwill
And when you checked the bulb first, that was ok?
Old Apr 12, 2010 | 02:30 PM
OHSBB45's Avatar
OHSBB45
Yes. Light works fine. Light comes on when ignition is turned off and it works when I turn the main domelight dial all the way.
Old Apr 12, 2010 | 04:59 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Does your "DOOR AJAR" warning come on when you close the doors? If so, liberally spray WD40 in the door latches. Exercise the doors and see if that works.
Old Apr 12, 2010 | 09:35 PM
OHSBB45's Avatar
OHSBB45
No. The door ajar light does not come on. None of the doors when opened cause the door ajar light to come on. I took the door completely apart and the wire that connects to the door ajar switch is not receiving power.
polarisman
2004 - 2008 F150
Apr 22, 2014 11:48 AM
timberon94f350
Apr 12, 2010 02:03 PM
cryintime
1983 - 2012 Ranger & B-Series
18
Aug 17, 2008 07:54 PM
singstream
Dec 16, 2007 02:53 AM
