Sponsored by: Auxito
steering column wiring
Old Jan 28, 2003 | 05:23 AM
markbo's Avatar
markbo
I recently bought a '97 f150 xlt and I'm begining to believe I own pandora's box.
On the way to work, I checked to see if the cruise control worked. It does, until I turn on the right turn signal at which time the cruise disengages!
From time-to-time my right turn signal blinks rapidly w/ no visual on the dash or @ the headlamp. Bulb, flasher ok. If I play with the turn signal arm I may get it to work.
Anyone else having these types of problems?
Old Jan 28, 2003 | 11:06 PM
Torque1st's Avatar
Torque1st
Posting Legend
Have you checked in the Electrical Systems and Wiring forum?
Old Jan 28, 2003 | 11:50 PM
Mil1ion's Avatar
Mil1ion
The Non-Cruise horn wire normally runs the power for the cruise.
Is the horn working fine?
How about the T/S does it cause a problem with the cruise too ?
Check inside the steering wheel center pad for shorting wires.
I suspect a problem in there or the turn signal switch area.
Everything is packed in the T/S switch area.
Old Feb 10, 2003 | 04:50 PM
myke's Avatar
myke
Hey Dennis,
I read your comments about the horn/cruise wiring. My wife's '94 T-Bird has had non-functional horn and cruise for quite a while now. I've looked under the column but didn't see anything loose or broken. Any suggestions?
myke
Old Feb 10, 2003 | 08:07 PM
Fordtrucktexan's Avatar
Fordtrucktexan
My truck's cruise works fine, but it just started doing that same turn signal thing you mentioned. I've noticed you'll hear it clicking real fast, with no illuminated dash indicator, and the amber exterior turn indicator light doesn't come on either. Just happens every once in a while though, post here if you find the solution.
Old Feb 11, 2003 | 02:23 AM
wmcnally's Avatar
wmcnally
Do a search on Clockspring harness and multifunction switch in the usual fora(forums). That should help. If you need more help post again.
Good Luck,
Bill
baileys no 37
Aug 29, 2011 12:00 PM
Duke78
Jan 17, 2010 04:58 AM
gda_99
Jan 28, 2004 05:02 PM
