Explorer Door Handle
Old Apr 11, 2010 | 11:37 PM
SmilinJack's Avatar
SmilinJack
Question Explorer Door Handle
I have a 1997 Explorer Sport and the driver's door handle return spring has broken or has come loose. I would like to replace the handle but the handle but what looks like "blind" or "pop" rivets, or "Hi-Locs" are attaching the handle onto the door. If so, are these rivets available other than from dealers and are special tools needed? Or am I completely out in left field?
Any help would be greatly appreciated....Thanks.
Old Apr 12, 2010 | 12:46 AM
scucci's Avatar
scucci
They are peel rivets -1/4" x grip range .090" - .115" Marson stock #42372. You can break off the peels inside the door with a small pair of diagonal cutters and then punch them out or you can drill them out with a 1/4" drill bit. It is easier to replace the rivets with button head 1/4" bolts (available in chrome from Ace hardware) and nylock nuts than to use rivets. Recommend getting door lock rod clip while you are in there-
Door Handle Rod Clip
Ford Part# E83Z-5421952-B
Dorman HELP! 75473
Auveco # 17122
Old Apr 13, 2010 | 01:11 PM
SmilinJack's Avatar
SmilinJack
Thanks. I was at a loss but finally got around to drilling out the rivets and thanks for the info on the replacement parts.
wikdwest
Apr 1, 2017 10:51 PM
troverman
Feb 17, 2017 03:17 PM
Buildingdavej
Nov 12, 2015 03:43 PM
fordguy55
Jul 9, 2010 09:54 AM
mat65
1983 - 2012 Ranger & B-Series
Jan 31, 2005 04:15 PM
