Modular V10 (6.8l)
rocker arms falling off???
Old Apr 11, 2010 | 09:33 PM
nicheff's Avatar
nicheff
99 f250, v10, 185k miles, stock
Removed passenger side valve cover and had three rocker arms laying in the bottom that had fallen off. Looked closer and the bolts holding the cam down were very loose, so there was no tension to hold the rocker arms on. What would cause this?? Also, when reapplying the bolts, they seemed to never get any tighter. (did not strip them, was careful) Any ideas? why would these bolts come loose? thanks...
Old Apr 12, 2010 | 07:09 AM
Johnny Langton's Avatar
Johnny Langton
Originally Posted by nicheff
Also, when reapplying the bolts, they seemed to never get any tighter. (did not strip them, was careful) .
In my world,this indicates stripped threads. I've never seen this,but it's not impossible. What happened right before the failure?
JL
Old Apr 12, 2010 | 06:44 PM
Fordfanatic4life's Avatar
Fordfanatic4life
yea gotta think it had been worked on previously..
if the threads wont tighten up then they are pooched..simple as that.
Old Apr 13, 2010 | 08:31 AM
MadMedic20's Avatar
MadMedic20
Back in the late 90's I heard of a similar problem with the 4V Cobra engines. I think it was Muscle Mustangs and Fast Fords that I saw that.
Old Apr 14, 2010 | 06:16 PM
mwsF250's Avatar
mwsF250
Sure sounds like a clueless gorilla got in there before you...
I can't see any reason why you couldn't attempt to heli-coil these... Could be a problem if the hole does not go deep enough, but it is sure worth a try.
speakerfritz
6.4L Power Stroke Diesel
Dec 10, 2016 07:15 PM
speakerfritz
Dec 6, 2016 08:35 PM
doug42190
Jun 10, 2016 10:25 AM
Milpool
Jan 31, 2016 10:13 PM
seafire
May 3, 2010 11:40 AM
