Sponsored by: Auxito
Will flashing OD light set a computer code?
Old Apr 11, 2010 | 04:57 PM
Dialtone's Avatar
Dialtone
99 F150 4.6 auto 175K miles.
Last couple of days, getting an occasional flashing Over Drive light. It seems to reset each time engine is shut off. No other apparent shifting issues. Fluid level is OK.
I cannot see any codes stored in the ECU. I could force it to come on at will with a hard acceleration across the 1-2 upshift point.
I know it is ready for a fluid change again, slight discoloration. Fluid and filter changed last at 100K.
Any ideas?
Old Apr 11, 2010 | 05:16 PM
projectSHO89's Avatar
projectSHO89
Yes, but a cheap scanner that doesn't support manufacturer-specific codes won't read many of the transmission-related codes.
Old Apr 17, 2010 | 11:13 AM
SnowHiker's Avatar
SnowHiker
that happened to me. was my od sensors and selonoid thinger jinger.
Old Apr 17, 2010 | 12:57 PM
projectSHO89
Yeah, that's pretty specific and helpful...
Old Apr 17, 2010 | 01:40 PM
SnowHiker's Avatar
SnowHiker
just sharing project. off course the world needs know it alls like u
Old Apr 17, 2010 | 10:13 PM
Ultramagdan's Avatar
Ultramagdan
Off topic. A proper scanner would help as mentioned.
Old Apr 18, 2010 | 08:32 PM
projectSHO89
“It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.” - Mark Twain
Old Apr 18, 2010 | 08:39 PM
jr32560's Avatar
jr32560
on my 95 it sent a code but it was a generic code took many tests to determine what the problem was-I finally got it figured out was my shift pack
yours could be a much different problem depends on what ya find doing the tests
Old Apr 18, 2010 | 08:41 PM
Ultramagdan
Enough of the personal attacks. Focus on Dialtone's problem.
Old Apr 18, 2010 | 10:10 PM
Dialtone's Avatar
Dialtone
Guess it dosen't really matter anyway.
Changed the trans fluid (all 14 quarts of it), cleared the ECU system and haven't seen any more from it for a week now.
Old Apr 22, 2010 | 03:45 PM
jackpiner57's Avatar
jackpiner57
2001 F150 XLT 4x4 w/7700 lb. package, auto trans, 5.4L,
My OD light has been flashing lately too. I've never changed the fluid, so I know it's time to (76,000 mi.) but I haven't been able to find any info on how to do it. I assume the torque converter also needs to be emptied? If so, how do you empty that? Is there a tutorial on this?
Old Apr 22, 2010 | 06:38 PM
Dialtone's Avatar
Dialtone
There isn't a drain plug on the TC so only way to get it all is to take it somewhere they have a machine to exchange the fluid.
Generally they tap into the upper cooling line at the radiator, start the engine, drain the old into a reservoir on the machine, and pump in the new at the same time.
If you decide to go this route, I suggest adding a pint/quart of Trans-X about a week before the exchange. The Trans-x will remove the varnish residues and condition the seals. Drive it for the week with the Trans-X in the system, then do the exchange. This is some good stuff and I have been using it on balky transmissions for nearly 30 years.
Be aware it has some Benzene in it, so keep it off painted surfaces and wash your hands good after handeling it.
jhl3
17
Mar 15, 2017 10:09 PM
pyrael
Dec 12, 2016 08:18 AM
KING-RANCH02
1997 - 2003 F150
Dec 9, 2015 08:43 PM
nick_ct_203
20
Sep 16, 2015 03:17 PM
utjer
Feb 23, 2010 09:31 PM
