Timing Chain while Replacing Water Pump ?
Old Apr 11, 2010 | 12:57 PM
sstrunk's Avatar
sstrunk
'96 Ranger Super 3.0L V6 5 speed; odometer broke at 190,486, guessing about 225K miles on chassis - used engine put in at about 150K (engine supposedly had 55K on it)..
Noticed rust in the coolant reservoir (replaced radiator & coolant about 3 years ago), and set about exchanging dirty coolant with distilled water at about 6 quarts at a time (did it once) - capacity is listed at 10.2 quarts. While driving truck to heat to operating temp for second exchange, heard god-awful squealing from engine - figure water pump bearings are shot. No problem, since we've owned the Ranger for almost 10 years, and I don't remember ever replacing it.
Question is: should I go ahead and replace the timing chain (or anything else) while I'm replacing the water pump? My oldest son is still in college, and I promised to provide him transportation until he graduates - could be up to 4 more years.
Second question is should I go with a Motorcraft water pump, or do you recommend another brand? Usually check RockAuto prices with local auto parts stores - any other sources you recommend?
Thanks in advance for your time and wisdom!
Old Apr 11, 2010 | 01:08 PM
g_k50's Avatar
g_k50
Check for slop in timing chain, replace if out of spec. Otherwise don't, i.e., if it's not broke, don't fix it.
Use Motorcraft pump, and I wouldn't recommend anyone use a reman pump of any kind.
ElMoco
46
Nov 28, 2016 09:42 PM
ollirrap
25
Jan 1, 2015 08:31 PM
superduty1967
Oct 1, 2012 09:11 PM
azu
Feb 14, 2008 02:48 AM
go-dog-go
16
Jul 3, 2003 02:39 PM
