2006 Coolant flush advice and comments
Finally got my fumoto valves today, I've been getting ready to flush and refill with Cat EC1 coolant, got 6 five gallons of distilled water, got the coolant, also got from ford dealer a radiator coolant flush CV1 (anybody heard of it? ) the guy at dealer counter said that's what they use, then I got a quart of CV9, recommended by many people to clean rust amd scale buildup. A lot of people recommend the Fleetguard prior to CV9. what do you think?
My truck's got 63k miles, i replaced my coolant begining of the year, but i've heard that the Ford Gold coolant could or might be responsible for gunk build up in the oil cooler due to extreme heat and chemical breakdown in the EGR cooler, then it becomes a chain reaction, oil cooler gets clogged, yet the coolant to the EGR comes from the oil cooler heat exchanger, less water=hotter egr,,, the chain of problems begin.
My biggest concern is flushing and clogging the oil cooler with loose gunk in the system, has anyone had this issue?
I downloaded the bulletin instructions how to flush step by step, it also explains to back wash the cooler but it has to be removed from the engine, is there a simple way of doing this without removal?
I also installed this weekend a coolant filter but have the valves closed, thought of putting it to service after the flush, but just got a reply from a member who adviced it be beneficial to let it start filter now febore flush to help remove anything floating around in the cooling system, makes perfect sence to me, i just went out to the truck, valves are open.
Sorry for the looong explanation but any advice or comments are welcome
Thanks
Nelson
Thanks
Nelson
Do you have problems with your deltas (EOT and ECT spread)? If your deltas are good than DO NOT do the chemical flush unless you plan on changing out the oil cooler etc...
I just did my pickup over the last 2 days. I had deltas of 3-5 degrees and I just wanted to swap out the Ford Gold for Cat ELC. I also swapped out the thermostat and the engine drain plugs for the Fumotos and they are a godsend for this application! There are 3 bolts holding the starter in place (if they haven't all rattled out) but the one on the top is a real buggar to get to. Apparently a swivel extension is the key!
I bought five 5 gallon jugs of distilled water for my flush and did the following.
- First flush was all distilled water (takes about 5 gallons with engine block drained on both sides as well as radiator)......
- before second flush I blew out the heater core with about 20lbs of air then filled again with distilled water....
- next I pulled the plugs on the block as well as the rad and ran tap water through the system for about 25 minutes... I also dropped the lower rad hose to get any crud out that might have been in there. Then with the tap running and the valves etc.. open I started the truck and revved it a little to blow any possible crud out of the system. Then filled again with tap water and drained. (did this twice)
- then flushed again with distilled to get rid of tap water.
- then filled her up with the good stuff! NOTE: Make sure to put all your coolant in first for your mix ratio.... a lot of water stays in the system even when draining the block! (close to 7.5 quarts worth!)
The tech folder has an awesome write up on how to do this and I also like these little videos.... I must have watched it about 5 times before doing my own! lol (it's 2 parts)
6.0 Liter Ford Powerstroke - Flushing the Cooling System with VC9 - YouTube
Here's part 2!
http://www.youtube.com/watch?v=XNKSToD7Gqg
Here's part 2!
6.0 Liter Ford Powerstroke - Flushing the Cooling System Part II - Including Why Oil Coolers Fail - YouTube
Thanks for all your info, good stuff, not looking forward to install the fumotos, but it's gotta get done if you want a good flush, the EC1 coolant back panel says if you have another type collant in the system it definetly has to be flushed at least three times (fill & drain) etc. WH 6.0 also does not recommend a chemical flush so I'll stay away from that, specially if the cooler and deltas still good.
In the Powerstroke Cooling System Flush v1-0 file i downloaded says that International made this engine and they use the CAT EC1 in other engines similar built like our 6.0's and they don't seem to experience the same issues we have with oil and egr coolers.
I just finished watching both videos you sent, excelent, greatly appreciated
Thanks
Nelson
It's a bit of work and will cost about 100.00 for the parts to fabricate the apparatus, but it can be used over and over again should the need arise.
I have resurrected 3 plugged oil coolers with mine without any problems.
Evapo-Rust
I bought a gallon for small parts on my 59 F100 4x4 project and the stuff is amazing. I was getting into chem backflushing my 6.0L but ended up changing the cooler and no longer have an issue, if I ever have rust issues I might try it.
Remove the oval shaped cap under the turbo. It is the coolant outlet for the oil cooler.
Now I could be wrong on the sizes and its raining cats and dogs right now, so I'll go from memory.
Get about 10 feet of 5/8 x 1/2 plastic tubing ( I used clear) and enough fittings to hook up one end to a garden hose with a ball valve between the garden hose fitting and the tubing.
Next remove the water pump. When you remove it you will see a large hole in the center of the front cover, it is the inlet from the block to the water pump. Place a rag in the opening. Around the opening the water pump fits in you will
find 3 opening, the one at the top at about the 2 o'clock position is the feed line to the oil cooler. Place a rag in the other two openings so trash you flush out of the cooler does not get into the block.
Place the 5/8 tubing into the top of the oil cooler as far as it will go. It is a tight (friction) fit and should stay in place when the high pressure water is applied. Turn the water on and use the valve on the tubing to turn the water off and on to "blast" the oil cooler. The water will come out of the top hole in the water pump housing. I purchased a kiddy wading pool about 10 inches in height and placed it under the truck to catch the water, but I let it overflow. Any solids will drop to the bottom of the pool.
I usually flush it off and on for an hour or two.
Next get about 10 feet of 1/2 x 3x8 plastic tubing. Insert it into the hole in the front cover where he water from the oil cooler comes out. It is a tight fit and at an odd angle but once it goes in you will be able to push it in about 8 inches.
The next thing you will need is a pump that will push about 6 gallons per minute, I used this one....
http://www.northerntool.com/shop/too...ct_16818_16818. A 2 or 3 gallon per minute pump will work if you can find one.
Get a 5 gallon bucket and place the discharge line from the water pump hosing in the bucket and run it near the bottom of the bucket. Use some other fitting to hook the supply line to the pump and put a short hose from the suction side of the pump into the buck, near the top.
Fill the bucket with your chemical of choice and circulate it through the oil cooler. At 6 gallons per minute it will leak quite a bit around the hose in the front cover, but with the valve on the pressure side you can reduce the flow to where it is acceptable. I used the kiddy pool to catch the chemical and reused it after filtering it through some blue shop towels.
I would run the pump for about 45 minutes then let it set for about 45, then run for another 45 and so on till I felt I had done it long enough. I usually do it all day long like that. The last time I circulated it I let it set overnight, circulated it the next morning and the flushed with high pressure tap water.
If you plugged the holes in the front cover you will lose a minimal amount of coolant and it will not contaminate what is in the block, radiator or heater core.
I do not heat the liquid, but it could be done. I would be very cautious about using any kind of electrical heating element unless you can make it 100% shock proof.
I used evaporust to flush mine, but one could use VC 9, restore, or restore plus or some other chemical you feel confident with.
I took pictures but can't figure out how to upload here
Nelson
