Wipers won't work
Old Apr 11, 2010 | 12:30 PM
tenforty_2's Avatar
tenforty_2
Wipers won't work
https://www.ford-trucks.com/forums/9...or-washer.html
Thought I would move this to a new section to see if I get a better response. Thanks for any help!
Old Apr 11, 2010 | 02:40 PM
Franklin2's Avatar
Franklin2
Here's some diagrams for a 2001. I couldn't get the 2002 to come up.
AutoZone.com Repair Guide Image
Looks like from the switch, if you took and jumped the pink/yellow wire and the darkblue wire together, the wipers should go to high speed. If they did, I would suspect the switch.
Here's a diagram of the wiring from the GEM to the wiper motor. One of the fuses is in the underdash fuse box (the 30 amp) and the other is in the underhood fuse box (the 10 amp). There are also relays located in the underhood fuse box.
Old Apr 12, 2010 | 03:57 PM
tenforty_2's Avatar
tenforty_2
Thanks for the links! I got a switch today.......will see what happens.
cjprkt
6.7L Power Stroke Diesel
May 15, 2017 01:17 PM
asavage
Aerostar
Oct 6, 2015 01:46 AM
drptop70ss
Aug 10, 2015 12:20 PM
1978f-250
Apr 5, 2014 09:53 AM
evan250
Sep 12, 2004 09:01 AM
