stupid question
Old Apr 11, 2010 | 09:36 AM
Liquid10Rider's Avatar
Liquid10Rider
stupid question
Hey guys I work on diesels all day but for a refrigeration company not pickups. I picked my 01 250 7.3 yesterday in PA and drove it home. while driving home I noticed when going down hill or when you let off the throttle the RPMs drop right to idle. But other times the RPMs stop at 1000 the engine stops making any noise then drops to idle and the noises come back. This sounds stupid but I'm just curious if that is normal or could the be related to the CPS??????????
Old Apr 11, 2010 | 09:45 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Totally normal.
The shift strategies that these trucks have as well as the injector lag time create the characteristics you speak of.
If someone wants more detail, I'll get into it. But for now, no worries.
Old Apr 11, 2010 | 09:57 AM
Izzy351's Avatar
Izzy351
When it drops to idle, your TC isn't locked. When it stays above idle, but the injectors are shut off, the RPMs will be up, but no injector noise. Like Cody said, totally normal.
Old Apr 11, 2010 | 10:05 AM
Liquid10Rider
thanks for the info!
Old Apr 11, 2010 | 09:40 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That's not correct.
When it drops to idle the coast clutch is not on and you're in a gear lower than 4th. It does not matter if the torque converter is locked or not, it can drive the engine either way. It will spin the engine about 10% faster during coast if the converter is locked, but it will spin it either way.
If the torque converter is locked, the trans is in 1,2,or 3, and the engine goes to idle speed it means the coast clutch is not engaged when it should be.
Old Apr 12, 2010 | 12:19 AM
Fire Rooster's Avatar
Fire Rooster
Originally Posted by Mark Kovalsky
That's not correct.
Huh thats funny.... My TC LED light turns off exactly when the injectors get loud while coasting. I am going with it's the TC unlocking and tranny has down shifted, as it was previously stated
Old Apr 12, 2010 | 04:54 AM
ron's power stroke's Avatar
ron's power stroke
if he is above 35 MPH -+ the RPM's should not drop to idle..the TC should stay locked....at least mine does...
Old Apr 12, 2010 | 06:34 AM
Liquid10Rider
the truck is rolling around 35-40 and the rpms either stay at 1k and the injectors stop then the rpms idle and you hear the injectors again or they drop right to idle. The previous owner did install a new rebuilt trans after the original went
Old Apr 12, 2010 | 07:22 AM
Izzy351's Avatar
Izzy351
Depends on tuning, Ron. My TC lock/unlock is set to different speeds depending on which type of tune I'm in.
Old Apr 12, 2010 | 07:42 AM
Izzy351's Avatar
Izzy351
That's not correct.
It's interesting that mine drops right when my tuner says the TC unlocks. And in my tow tune, the TC stays locked to about 30mph in 3rd.
Old Apr 12, 2010 | 07:49 AM
Fire Rooster
Tested it last night. Flipped my TC switch and kept it locked up down into 1st gear. 15mph, 1000rpm's unlocked it. Injectors were quiet all the way down till I unlocked it.....so to answer the original posters question. Everything is fine, and yes as you were told the noise u hear is after the TC unlocks the rpms drop down to idle and the injectors are firing. Now worries man u r good
Old Apr 12, 2010 | 07:53 AM
nhill2090's Avatar
nhill2090
Originally Posted by cleatus12r
Totally normal.
I wouldn't mind a little more detail
Old Apr 12, 2010 | 04:18 PM
ron's power stroke
mine with a chip the TC locks at 27 MPH and stays locked on down shifts too..but i didnt see any mod's listed..so i assumed we were talking about a stock truck...
Old Apr 12, 2010 | 04:24 PM
BillyBob69's Avatar
BillyBob69
Coast Clutch?
Old Apr 12, 2010 | 07:56 PM
Mark Kovalsky
You can go with that, but you don't know how a transmission works.
I think your trans is shifting from 4 to 3 when the converter unlocks. That's why it drops to idle. What you say just doesn't make sense when you understand the powerflow through the transmission.
