56 big back window?
Old 04-11-2010, 12:40 AM
thrifty's Avatar
thrifty
thrifty is offline
56 big back window?
Is there any way to look at the vin and tell if the truck came original with the big back window? If so, what is the letter or number? I know that you could check the cab to see if it was welded, or a fiberglass kit added. Any help would be great.
Thanx
Old 04-11-2010, 07:29 AM
kdmcinnes's Avatar
kdmcinnes
kdmcinnes is offline
In 56 all big back windows were steel, fiberglass kits are new (as in the past ten years or so). Not sure on the vin code for a big back window. Is the back of the cab fiberglass or steel?
Kyle
Old 04-11-2010, 09:11 AM
WALFORD'S 56's Avatar
WALFORD'S 56
WALFORD'S 56 is offline
There is no number in the vin to say it was a b.w..
The b.w. is getting easier to build and I just helped a guy do a cab and it was not hard.
You can also buy a bebops fiberglass cab with the b.w. feature,if you like it.
Old 04-11-2010, 09:14 AM
mr4speedford's Avatar
mr4speedford
mr4speedford is offline
There is nothing in Vin Code that will tell you if its a original big window. As you stated, you could look for evidence of a window being added. Somebody swapping a original big window cab onto a different chassis and you'd never know.
Old 04-11-2010, 01:10 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,468 Likes on 1,408 Posts
The information in the vin includes the model year, engine type, assembly plant, and consecutive unit number. Nothing about body options.
That said, there may be a code on data tag stating if it is the deluxe, custom cab model, or a standard cab. While that won't tell you for sure if it's a big window, I believe it would rule out the possibility if it's a standard cab. My understanding is the big window was optional on custom cab models. The 56 experts here may be able to verify that.
Old 04-11-2010, 07:30 PM
old uhaul's Avatar
old uhaul
old uhaul is offline
You could actually get a big back window in any trim either standard or custom cab.I had an f500 that had standard cab trim but was a big window,which gave stainless trim around all the windows.These days with the steel big window panel available any cab could be converted.Its no harder to weld that in then the lower patch panels for rust repair.If you have a small window and want a big window then just make it but if you do sell it make sure you tell the buyer its a conversion.If it is done correctly it should not be a big deal.I drive my trucks and prefer the small window because the sun doesnt burn my neck so much!
Old 04-11-2010, 08:11 PM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
post delete
Old 04-12-2010, 01:59 AM
thrifty's Avatar
thrifty
thrifty is offline
Thanks for all the input. Terry has a big back window but it's a conversion, the cab is a little rusty so if I decide to I will convert mine to a big back window. I really like the idea of a metal one opposed to the fiberglass. He also has the fiberglass complete rear section from the top seam to the bottom of the cab. The metal is less material and work to take out, and a lot of bracing So if I do the metal conversion I will have to go buy a wire feed. ( Good excuse ) That's what I'll tell the old lady. (dog house here I come!!!!)
Old 04-12-2010, 07:59 AM
Truxx1956's Avatar
Truxx1956
Truxx1956 is offline
Talking
Hey Old Uhaul, if you do get your neck burned good you could be a redneck and might fit in down south with us better. It might not be as obvious that your a Yankee? I'm just pickin on ya, are you comin back down this year? Are you goin to have something to drive with us this time?
Old 05-02-2010, 08:07 AM
old uhaul's Avatar
old uhaul
I will be down this year with something.If all else fails i will drive the panel down and then i can cruise with you.Looking forward to the show and seeing everyone
Old 05-02-2010, 09:57 AM
homade's Avatar
homade
homade is offline
Uhaul, we've been wondering what you would show up with this year, see you next month, Garry
Old 05-02-2010, 10:22 AM
old uhaul's Avatar
old uhaul
Hope you are doing well and looking forward to next month.The past year was real tough with way too many setbacks.I think i will drive the panel down this year.
Old 05-03-2010, 06:50 AM
fergusonicford's Avatar
fergusonicford
fergusonicford is offline
So with all of the aftermarket BW panels being put in regular trucks; do you think this de-values the original Big Windows?
Old 05-03-2010, 06:58 AM
old uhaul's Avatar
old uhaul
people have been this conversion for over 25 years.A big window truck will always bring a little more money,original or not.
Big_frita
Projects
07-14-2017 06:50 AM
Outlaw56
30
11-11-2016 09:59 AM
tiltbilt
38
11-23-2015 10:03 AM
glassmanbruce
09-24-2015 08:02 PM
no1lowr
1961 - 1963 F100 Unibody
10-20-2009 03:12 AM
Quick Reply: 56 big back window?
