Well when I turn the ignition to start it only clicks, i had the starter tested several times at three different places passed everytime its only 3 months old. I have checked all the fuses and relays all good im lost at this point any advise would be greatly apprecaited! Thanks!
doesnt matter if batteries were charged... i charged mine with my battery charger till the lil green light went on..... but i took em in to get tested and they were BOTH bad..... my batteries were about 5 months old and BOTH were bad... its free to get them tested. its a good place to start...
I have two new batteries, a new relay and a new starter and I still have clicking issues. I won't work them out till this summer though when its warm outside.
Same here had to take them to two different AZ'z for a second opinion. They would NOT hold enough power to hold a second load.
I get a single click over and over with the occasional start. This is the only thing I haven't tried yet. Sometime it even dies right in the middle of turning over. Sorry to high jack the thread.
Never mind! That is just a 20 fuse under the dash. I checked the power box under the hood and found two 50 maxis labelled as ignition switches. Neither of them seem blown.
Today I took my cables off and wire brushed them and the terminals on the batteries. I all ground down the cable enough so that they would firmly tighten around the terminals. Still clicking!
