AOD Fluid Capacity Help
If you are changing the fluid it would be better to drain the torque converter as well as the pan, as that is where the bulk of the old fluid is. If you rotate the converter you should find the drain bung.
By | 2026-05-18 19:34:33
By | 2026-05-18 19:26:42
By | 2026-05-18 19:20:37
By | 2026-05-12 18:07:46
By | 2026-05-12 13:09:47
By | 2026-05-12 12:50:07
By | 2026-05-07 17:51:06
By | 2026-05-05 11:17:22
By | 2026-05-04 13:49:49
By | 2026-04-29 16:49:01
