aod leaking
Old Nov 30, 2014 | 11:32 AM
fordboy97's Avatar
fordboy97
aod leaking
The truck is a 1990 f150 with the aod trans. I'm getting ready to fire up my new engine but I noticed that overnight there is a puddle of trans fluid underneath the trans pan area. It looks like the pan itself is leaking because it appears to be seeping out around it but I'm not 100% sure. What else could be leaking in the pan area? I can see the gasket bulging out around the bolts.
I recently did a fluid and filter change, so I'd like to drop the pan and replace the gasket and filter but only add back what came out from pan removal. Any idea how much I should add?
Tanner
Old Nov 30, 2014 | 04:24 PM
fordboy97's Avatar
fordboy97
Bump. Is the pan the only thing in the front of the trans area that could be leaking? Its dry where the engine and trans meet.
Tanner
Old Nov 30, 2014 | 07:49 PM
blueoval66's Avatar
blueoval66
Is it a 4x4 ? If so they have a trend to leak at tranny tail shaft to transfer case due to bolts loosening up.
Old Dec 1, 2014 | 08:26 PM
fordboy97's Avatar
fordboy97
No its 4x2. I figured it out, it was the dipstick tube. Put in a new o-ring and no more leak.
Tanner
Sullid01
Mar 17, 2022 08:21 AM
Dlras
Nov 19, 2017 07:01 PM
'74 Ford 250 CS
Oct 22, 2017 07:36 AM
steverinaz
Jun 23, 2017 10:20 AM
Eicca
Aug 3, 2011 12:07 AM
