Turbo Question
Old Apr 10, 2010 | 02:55 AM
1999SuperD's Avatar
1999SuperD
Turbo Question
So what are all the mods you guys are doing to the turbos on our truck? What are the best ones to do.
Old Apr 10, 2010 | 06:31 AM
Kwikkordead's Avatar
Kwikkordead
It really depends on your intended use for the truck.
You want to tow a big trailer with it? Then IMO it's best to leave it stock or at the most a slightly larger exhaust housing. You want to build boost early and keep it there so that a lot of air goes through the engine and keeps the EGT down.
Want to put huge injectors in and run it at 3000+ rpm? Then you need a larger turbo.
Bottom line, tell us your intentions with the truck, then you will get a better answer.
Old Apr 10, 2010 | 07:56 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
A lot of us just replace them like Dan said. I went to a TN BB turbo, but you can't get them anymore, so the 38R is popular now.
Old Apr 10, 2010 | 01:21 PM
PwerStroke99's Avatar
PwerStroke99
Go with a 38R and be done with it
DIYMechanic
Jun 21, 2011 02:50 PM
LETMGRO
Feb 2, 2011 08:37 PM
wilbur996
Feb 8, 2009 06:42 PM
twwtruck
Jul 11, 2008 11:33 PM
CowboyFromHell
17
May 3, 2008 11:38 PM
