np435 1st and reverse question
Old Apr 10, 2010 | 12:29 AM
quaallen's Avatar
quaallen
hey i got a 79 f150 4x4 with 4speed. i think its np435.. not positive ...anyway my 1st and reverse will pop out of gear. HARD!!! cant hold it in place. it pops under higher rpm but whines o r grinds in 1st and reverse at all speeds.i know that they whine but it never whined this much untill it started SLAMING out of gear. i was told it was the syncronisers...but seeing how these trans dont have syncronisers in 1st and reverse, i dont quite know.. what do they use then?? what causes this SLAMING out of gear, and noise??? could it be just the amount of bind on it?? HELLLLLLLPPPPPPP!!!!! im sure someone knows.. please help and thank you guys
Old Apr 10, 2010 | 11:02 PM
85e150's Avatar
85e150
Popping out of gear is worn shafts and/or other internal parts.
ID your trans here:
Domestic Truck Tranny Guide
Do you:
--have enough tools, time and experience to try to rebuild it yourself?
--have a trans shop you've dealt with and trust & the money to pay them $500 for an overhaul?
--a scrap yard nearby, a friend with nothing to do and some tools and good luck at finding usable things amongst the unusable?
Your trans needs a rebuild or replacement.
Old Apr 11, 2010 | 09:13 AM
andym's Avatar
andym
Yeah when a manual tranny starts popping out of gear like that it's telling you it needs a rebuild.
Old Apr 11, 2010 | 10:27 PM
quaallen's Avatar
quaallen
yea i agree with the rebuild.. im not going to pay a shop to rebuild it..i have never done it but i feell confident. have a few guys i can ask for help and i can get instructions and i enjoy wrenching.. it not a daily driver eather so i can take time to do it.. so that being said, oh and thank you guys for the advice, what are my options when it comes to rebuid kits?? if im going to rebuild it i want to rebuild it THE RITE WAY!!! ive seen rebuid kits on broncograveyard but do they make anysort of "upgrade" kit for the np435?? if i DO have to replace gears should i buy different ratio? do different ratios cost more? what all advice can you guys give me when it come to picking out rebuid kit?? thank you guys
Old Apr 11, 2010 | 11:10 PM
85e150's Avatar
85e150
Rebuild kit should be synchros, bearings, gaskets and any shifter bushings that would wear.
If you open it up and find damaged gears, I would just get another trans. You will spend a fortune for new gears, or will have to buy a donor anyway. Ymmv.
Old Apr 11, 2010 | 11:26 PM
quaallen's Avatar
quaallen
thank you good sir...i dought the gears are bad. it still shifts fine. just askin for an oppinion...you think i shoud put a new cluth in it while im at it?? im thinkin a dirt digger..im not having problems with my cluth just askin you guys,,,thanx
Old Apr 11, 2010 | 11:39 PM
85e150's Avatar
85e150
Unless the clutch is fairly new, replace it--all components. The labor is the tough part, so you're almost there once the trans is out.
Good luck with it.
Old Apr 12, 2010 | 08:11 AM
andym's Avatar
andym
The first thing you need to do is identify it. The T-18 and the NP435 look similar from the outside but my T-18 has a big "Borg Warner" logo cast into the driver's side.
I have a link to a really good T-18 rebuild article. If that ends up being what you have let me know and I'll post it.
Bigcjsbronco
Jan 28, 2017 10:30 PM
Bigcjsbronco
1978 - 1996 Big Bronco
Jan 20, 2017 08:57 AM
towmaster
Mar 9, 2016 01:41 PM
BlueOvalBud
Feb 20, 2010 07:54 PM
Doorgunner808
Jun 27, 2002 01:16 PM
