82 300-6 distributor
Old Jan 27, 2003 | 07:55 PM
MEPR's Avatar
MEPR
Ok i need to know if the advance on these things is just vacume opperated. And if so can i get one that has both vac and cintrifical advance. Thanks.
Old Jan 28, 2003 | 01:31 PM
Ford_Six's Avatar
Ford_Six
Should be both already- that is stock. To check it, take the cap off, and try to turn the rotor back and forth. It should turn forward a little, and snap back. If not, just get a rebuilt one.
Old Jan 28, 2003 | 09:14 PM
quads's Avatar
quads
you can also get a vaccum pump attach it to the centrigal advance pump it up should increase the idle of the truck as it is advanceing the timing when you do that
Godbless
quads
Old Jan 28, 2003 | 10:04 PM
MEPR's Avatar
MEPR
well i just though about this while i was working on it tonight, i could just plug the vac line put a timing light on it and then rev it. If it moves then theres a mechanical, if not just vac.
Old Jan 28, 2003 | 10:51 PM
Aero426's Avatar
Aero426
I also have an '82 300 engine with a distributor of unknown vintage. It is a points unit and has no provision for mechanical advance! Don't all distributors need to advance timming with rpms?I want to retain the points but surely need to advance timming,especially at W.O.T?
Old Jan 28, 2003 | 10:52 PM
Ford_Six's Avatar
Ford_Six
Ok, let me rephrase: if there is no centrifugal advance, then the dizzy is bad. Period. It can be rebuilt, but after spending $40 in parts, and an hour of your time, you just may want to replace it with a $45 rebuilt and tested one. But ALL 300-6's AFAIK have a vacuum advance too. There are specs in the shop manual for what the advance is supposed to be at what rpm. Are there problems with the truck that make you suspect a non-functioning advance?
F-250 restorer
Feb 4, 2013 12:49 PM
V10man
Feb 2, 2013 11:35 AM
dustybumpers
May 26, 2009 08:26 PM
madmader
1978 - 1996 Big Bronco
Aug 4, 2005 09:04 AM
lyonexplorer
Dec 26, 2004 08:53 PM
