o ring?
Old Apr 9, 2010 | 02:58 PM
bluescrew's Avatar
bluescrew
o ring?
i am pretty sure its just a o ring
Old Apr 9, 2010 | 03:03 PM
SpringerPop's Avatar
SpringerPop
When you have it off for replacing, be sure to take that tube to the wire wheel to clean off the scale and rust, use metal prep, and then at least primer and paint it.
Otherwise, you're going to have a leak that just a new o-ring can't fix.
Pop
Old Apr 9, 2010 | 08:22 PM
DND58's Avatar
DND58
Man Pops, I hope not. I just did this project today. It was starting to leak as temperature is changing. Old o ring was brittle and trash. I just cleaned everything up well, used some faucet lube on new o-ring. So far, no leaks.
Old Apr 9, 2010 | 08:26 PM
SpringerPop
Rub some of that faucet lube into the rust scale to retard it a bit?
Just a thought...
Pop
Old Apr 10, 2010 | 01:16 AM
bluescrew's Avatar
bluescrew
ill just swap out that 90 for a new peice.. no scaling then
Old Apr 10, 2010 | 06:43 AM
Kwikkordead's Avatar
Kwikkordead
Get some new clamps too.
Those spring clamps are great, but if they get rusty they get weak.
Old Apr 10, 2010 | 09:36 AM
danskool's Avatar
danskool
Go Bills !
Mine did this a couple years ago. I noticed a spot on the floor about the size of a Beer can. Saw the same as in the picture.. When i went to address the issue i noticed It stopped all on its own. Two years later still nothing.. It was wierd.. But i am going to address it when i do the coolant change in the near future.
lethal01
Oct 22, 2014 01:57 PM
fast70
Oct 13, 2010 10:53 PM
ArcticF250
Apr 24, 2010 09:50 AM
KevinC.
Apr 6, 2009 05:32 PM
