Sponsored by: Real Truck
Intermittent Steering Ghost
Old Apr 9, 2010 | 11:55 AM
thomabb's Avatar
thomabb
I have a VERY intermittent steering problem with my 2002 F250 7.3. After making a right turn, the wheel will not go back to center easily. Then the wheel will jerk to the left just hard enough for the truck to track off. I can center the wheel, but it just tugs to the left again. It will continue until I stop the truck.
I can not reproduce the problem on demand. It has happened less than 5 times in the last 3 months. The garage aligned it two weeks ago, but it happened again this morning. When it happens, the truck is nearly uncontrollable. The tires are almost new.
Is there a component in the steering box that can fail and cause this type of intermittent issue?
Old Apr 9, 2010 | 03:36 PM
BillyBob69's Avatar
BillyBob69
I am thinking along the lines of a binding caliper. Could be something with the right turn that is causingthe left caliper to bind up and when you come to a stop, it allows it to release.
The other thing I would look at, if it is a 4x4 is to make sure the hub is released and not catching the drive axel. Then make sure your t-case is fully releasing out of 4x4. If no 4x4 then check bearings. Jack up the front end by the suspension and have a buddy turn the wheel left and right to see if you can spot anything catching. Could be a binding joint somewhere like the tie rods, a-arms, etc.
Old Apr 9, 2010 | 06:24 PM
johnbox's Avatar
johnbox
You might want to also check your front u-joints to see if one of the caps has siezed on the cross. Had this happen to me with similar symptoms - even though I wasn't in 4x4 at the time.
Old Apr 9, 2010 | 07:43 PM
Fordfanatic4life's Avatar
Fordfanatic4life
a dried out Balljoint could also be suspect..
time to get that front end in the air and give everything a good look over while you turn left and right...
Old Apr 11, 2010 | 09:18 AM
thomabb's Avatar
thomabb
I did find a bad U-joint yesterday on the left. I've only driven a couple miles since, but so far so good. Couldn't find anything else wrong. I didn't think the U-joint would cause an issue in 2wd?
Old Apr 11, 2010 | 11:14 AM
DaveandJennyP's Avatar
DaveandJennyP
A friend of mine's '99 did the same thing. It was all over the road caused by stuck u-joints even when in 2wd.
Old Apr 11, 2010 | 11:21 AM
SpringerPop's Avatar
SpringerPop
Though I don't know the intricacies of the power steering box, it sounds like you are describing a problem that can also be caused by intermittent internal hydraulic valving problems. A complete change of power steering fluid may help. How long since it's been changed?
Most here recommend Mobil 1 synthetic ATF as the new fluid. It takes from three to four quarts to pump out all the old and replace, and there's a written procedure here:
https://www.ford-trucks.com/forums/9...ml#post8338085
It may help. Then again....
Pop
Old Apr 11, 2010 | 04:37 PM
Fordfanatic4life
even when your not in 4WD the axle U-joints still twist abit when your corner everytime..
Old Apr 11, 2010 | 09:23 PM
thomabb's Avatar
thomabb
UPDATE - The problem still exists. Replacing the bad U-joint did nothing. I am going after the steering box next.
Thanks to everyone for the advise. When I find the problem I will post it here.
Old Apr 13, 2010 | 09:11 PM
thomabb's Avatar
thomabb
I had the ATF flused today. Tech said it looked pretty bad. I am going to put a couple hundred miles on her this weekend. We'll see how she does.
Old Apr 13, 2010 | 09:14 PM
Pinky Demon's Avatar
Pinky Demon
U-Joints. Front ones.
I had the same problem as you. There was a massive thread dedicated to it. Got the truck aligned, threw in a RedHead steering box, new PS pump, all helped but didn't stop it. Finally, U-joints solved the issue. No problems since.
Old Apr 13, 2010 | 09:15 PM
Pinky Demon
Also, when it starts jerking, stop and rapidly move the steering wheel lock to lock back and forth. Some times you might hear a pop, sometimes not, but it should fix the issue until something binds up again.
Old Apr 13, 2010 | 11:15 PM
EXv10's Avatar
EXv10
I'm the one that had the marathon thread and Pinky and I were going nuts. Here read this;
https://www.ford-trucks.com/forums/8...ml#post8768063
Old Apr 14, 2010 | 07:12 PM
beerguy214's Avatar
beerguy214
I was just gonna start a new thread mine is doing almost the same thing.lol.Just started the other day.When i make a right turn and straighten out the trucks dosen't jerk but it is almost like the power steering went out .Steering is real hard to turn back and forth and it pulls real heavy to the right.If i let go of the steering wheel it will go right into the right lane.But then if i drive a mile or so it will stop.Only happens 1 day but not everyday.So does this sound like a bad u joint?
Old Apr 14, 2010 | 09:19 PM
EXv10's Avatar
EXv10
That's not the same problem we had.
