Sponsored by: Real Truck
Steering Problems
Old Apr 13, 2010 | 10:59 PM
EXv10's Avatar
EXv10
Originally Posted by thomabb
Did you find the problem? I am having the very same problem with my 02SD! The garage found a bad U-joint, but it didn't fix the problem. I suggested the spool valve in the steering box, but he said that wasn't possible. I am headed back to the shop for the 3rd time!
I had a marathon thread going in here on that problem (search; steering jerks back and forth). Mine would suddenly turn right then left then right etc and you could watch the steering wheel go through the motions. I replaced the PS pump and that took care of 90% of it and then I replaced the belt so now it is fine. I could stop on a gravel shoulder and pull the wheel back and forth a few times and it would be fine for a while. That was 6 months ago. I also sprayed the front u-joints with penetrating oil at the same time while turning in circles but I don't know if that was the problem. It did cure the dried out u-joint wiggling problem though. I was leaning towards the spool valve but if that was it it just didn't have enough pressure going to it. Still a mystery to me. It was a month after it was fine that I sprayed the joints.
B HOOFED
6.4L Power Stroke Diesel
24
Aug 23, 2016 05:26 PM
Longhand
1983 - 2012 Ranger & B-Series
Feb 24, 2015 11:06 AM
aaron1969
New Member Introductions
Dec 12, 2014 09:40 PM
brzehentmaier
Nov 15, 2014 08:10 PM
