1966 F100 custom cab
Old Apr 12, 2010 | 01:06 PM
baracade's Avatar
baracade
Originally Posted by camperspecial65
It is the window washer switch...plain black button...that type is used on 65 trucks...I bet under the hood theres 3 cowl access plates retained by 2 screws diagonally...gas pedal is prolly bolted to the floor too vs suspended like later 66 trucks were...these truck could have had 1 or all three of these setups as these are leftover 65 cabs..if your gas pedal is suspended...look under the cab near where your heel sits when driving...I bet there is 2 cage nuts there about 1 1/2" apart...
The 66 trucks as designed did have the pull for wash type window washer switch as Bill mentioned...yours just has one that used a leftover 65 cab it sounds like.
- cs65
My truck has the suspended acclerator. Who can I get to decode my vin #?
Old Apr 12, 2010 | 03:54 PM
Bill W's Avatar
Bill W
Numberdummy! just post the vin and i'm sure he will de-code it.
Old Apr 13, 2010 | 06:29 AM
baracade's Avatar
baracade
Thumbs up vin #
vin # F10YD873265
Please decode, thanks
Old Apr 13, 2010 | 06:58 AM
BarnieTrk's Avatar
BarnieTrk
Arrow
vin # F10YD873265
WELCOME TO FTE, Baracade!
VIN# F10YD873265
F10 = F100 model, 1/2 ton, 2wd.
Y = engine code, 352 V8 with a 2-barrel carb
D = assembly plant code, assembled in Dallas, TX
873265 = consecutive build number. Your truck was assembled in June, 1966.
If you provide the information from the Warranty Data Plate - the metal plate located on the side of the driver's door, below the latch - then we can decode more information on how your truck was equipped when it was assembled (assuming it is the original door).
BarnieTrk
Old Apr 13, 2010 | 11:23 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
(sigh) You of all people!
I wouldn't be surprised if a didn't know...but not a long time owner/parts scrounger like yourself that also has the parts catalog.
Text / Section 97, Pages 13 & 19:
C5TZ9725Z .. SUSPENDED Accelerator Pedal
C5AZ9735D .. SUSPENDED Accelerator Pedal Pad
Fits 1965 F100/2WD from serial number 696,001 / 1966 F100/250 2WD.
Old Apr 13, 2010 | 08:44 PM
Old_Crow's Avatar
Old_Crow
Dang I hate that "middle of production" changes. Cost me a day on a Ranger I was working on the other day.
Old Apr 13, 2010 | 09:36 PM
myutesux's Avatar
myutesux
HOW DID WE CHANGE SUBJECT'S HERE
I still would like to know what these other relay switcher are for i have picture's in my album's of dash thanks also still looking for site that has Australian code's for AUSSIE truck's
this is what I have
prefix body AL2JPY
SERIAL NO;22810
SIDO;746695
MODEL;73412
ENGINE;E
RR AX 1
TRANS;L
TRIM;S
PAINT;3
Old Apr 13, 2010 | 11:09 PM
OldHarley's Avatar
OldHarley
Patrick,
I am not sure we changed subjects. Your album says you have a '74 F250. You might get an answer in the '73-'79 forum.
By the way the switches look to have been added. Not sure what they are for, maybe aux lights?
Papawheelie
30
Feb 23, 2017 05:14 AM
Alanok
1947 and Older Ford Trucks
21
Jun 30, 2016 05:51 AM
porthole
6.7L Power Stroke Diesel
May 16, 2012 06:34 PM
RANGER589
18
Jun 3, 2011 10:03 AM
