Transmission Issues
Old Apr 8, 2010 | 01:37 AM
Mugenlude's Avatar
Mugenlude
Transmission Issues
I started running into these transmission issues in the last couple days...
2000 Excursion 7.3L... 140k
Two days ago which cruising on the highway (70 mph w/ UD on) the transmission jarred, almost like it went down a gear and then right back up... one big thud and the truck jarred.
Today the same thing happened about 15 times over a 70 mile trip, it also stalled while slowing as I came to a light, and once while I was parking it. It also jarred while pulling away from a light going into 2nd gear.
Thoughts??? hopefully good ones, as I'm not optimistic....
Old Apr 8, 2010 | 06:24 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Remove the driveshaft and lube the slip yoke. Ford sells a special long life grease for this.
Old Apr 8, 2010 | 06:55 AM
Nosedive1's Avatar
Nosedive1
I may be wrong, but the stalling kind of sounds like a cam position sensor.
Old Apr 8, 2010 | 07:48 AM
Mugenlude's Avatar
Mugenlude
Thanks for the recommendation Mark, sounds pretty straight forward, anything I should be paying attention for when I do this? Any special tools that I might need?
Old Apr 8, 2010 | 07:50 AM
Mugenlude's Avatar
Mugenlude
I did receive a recall notice in the mail about the CPS. I have heard of the issues, but from what I read I thought it just died and that was it, I didn't think it would restart. Either way, if I have to go to Ford to get the long life grease that Mark suggested I can get the new CPS at the same time.
Old Apr 8, 2010 | 08:07 AM
Nosedive1's Avatar
Nosedive1
I have a V10 in my excursion, but when I had my F-350 with the 7.3L the CPS started to go out, it would hiccup going down the road and then a couple of days later it started stalling, but it would always restart. I have heard of them going bad all together and the engine dieing and not restarting, but I guess I was just lucky with mine in that it never left me stranded.
Old Apr 8, 2010 | 09:45 AM
Mugenlude's Avatar
Mugenlude
If this is the problem, then this emotion is in order...
Old Apr 9, 2010 | 07:02 AM
Mugenlude's Avatar
Mugenlude
Well, I changed out the CPS (got a grey one).... took a 30 minute drive, no issues. Thanks FTE!
abe
32
Oct 24, 2016 09:55 PM
phoskins
Sep 13, 2016 07:48 AM
jdstudski
Aug 8, 2013 05:57 PM
bcsawyer
Aug 7, 2013 09:13 PM
97flairside
1997 - 2003 F150
Mar 2, 2011 07:16 AM
