few questions getting ready to do injectors
Hi guys so finally the weekend is almost here going to be starting my injector replacement Friday I will be doing an oil change, coolant flush aswell I just have a few last questions, I would like to know where the drain bolts are on the block for the coolant and would also like to know torqueing specs and sequence for valve cover, lastly do I use a gasket maker on the valve cover gaskets? like Permatex gasket maker?
Valve cover gaskets are re-usable, unless you damage it during repair. DO NOT use silicone or gasket maker, or any type of sealant for that matter. Use a 12mm back up wrench to hold the studs from turning during removal of the FICM bracket nuts and such, to prevent it from turning. Tighten the valve cover fasteners using common sense.
You need an 8mm allen socket to remove the block drain plugs.
on
hey chan and cheezit would it hurt anything if I changed the oil in this order, drain oil then replace the injectors and assemble truck then add new engine oil and try to start truck? by the way I chose the rotella t6 5w-40 to put in the truck and I will use oem motorcraft oil filter
Jgostrenga49855
01-12-2013 06:16 PM
IamMeYouAreYou
05-01-2012 01:38 PM
Schuyles
03-30-2012 05:47 AM
tealboy1
06-05-2007 11:18 AM
power_speed
10-17-2006 08:05 PM
