I need to remvoe the upper intake to chang the valve cover gasket on the pasenger side. The repair manual says there is six attachment points. Five are normal bolts I can get to. The last is in the middle on the passenger side. The manual identifies it as a screw. My question is what type of screw is it? I can go past the valve cover with my hand. I believe a 5 mm hex fits it okay but since I cannot see I am not sure.
Any Ideas?
One more question do I need to use gasket maker on any of these surfaces?
I've used a gasket maker on my intake, I applieed a very thin amount on the intake side to help seat the gasket and let it dry before torque it down in a x type of pattern. and did the vaalve covers the same way, I used the rubber with the steel inside type of gasket.,,as I didn't want to redo it later next year because of strinkage problems likr you get with cork.
Reamer did you ever get your engine working right?
Any Ideas?
Here is the tool for the torx screw in the middle, You can find it here
