steering
Old Apr 7, 2010 | 04:37 PM
77dragf250's Avatar
77dragf250
steering
hello, im converting my 1977 f250 with a built 460, built c6, 3.55 dana 60 rear, lightened truck, over from the stock steering, to a manual rack and pinion. i am putting a control arm setup in the front also.
Does anyone have any idea if this is
A-possible
B-affordable
C-a write up?
is this a bad idea? i can get the rack and pinion for less than 100 bucks..
Old Apr 7, 2010 | 06:47 PM
75F350's Avatar
75F350
I believe this swap is most commonly done with 1/2 tons using the more desirable 9 inch rear end, and the crown vic front end.
Should be some tech stuff around.
Old Apr 7, 2010 | 07:01 PM
mud bros's Avatar
mud bros
rock and peanut steering is really light duty unless you use a rack from a later model ram?f150?
even then its iffie with the tre sizes and overall size.
maybe if you downgrade to a windsor with alum heads and a lighter trans you can get away with it.
even with extensive lightning your still a portly 4000lbs a bit much for a mustang rack(i assume your planning on using) and if your alignment and scrub is not spot on its going to be working really hard
failure is not an option when working with steering and suspension
Old Apr 8, 2010 | 09:56 AM
77dragf250's Avatar
77dragf250
thanks guys, i will search the tech threads to try to find something. if not and i decide to go as planned, i will have to do a tech write-up for it with pictures and such.
Jeepman3
Jul 6, 2014 06:48 PM
DJ_Brown
Oct 2, 2008 04:56 PM
rubiconwarrior
Jul 13, 2007 01:41 PM
jimbobtaylor
Sep 10, 2004 12:52 PM
rv21350
Nov 28, 2001 05:43 PM
