After it warms up it will start running rough and then if you give it gas it will run extremely rough with no rpm gain and sometimes it will back fire through the carb and/or exhaust. It does shake, sputter,pop and even sometimes it will "diesel".
EGR may be a possibility. do you have one? Didja check it out?
I replaced the oil sending unit today and the truck seems to run alot better even after it warms up. The sending unit was spraying oil out of the top. I wonder if that would create some kind of a vacuum leak?
I also noticed now that my fuel pressure is fluctuating between 4-7psi. Fuel pump going bad maybe? I am still going to replace the magnetic pickup, ignition coil and egr valve.
I am almost certain it is electrical, I would test all the plug wires with a ohm meter, change the pickup coil, and I would even swap out the ignition control module. Worse case is the module is good you will have a spare and they fail at the worst times.
How do i test the plug wires with an ohm meter? Like what setting on the meter and what not?
Just because the ignition module tested good at the parts house doesnt mean that it is good, if the sales rep knew what he was doin he woulda told you this. I have seen them test good when they are cooled off, then as soon as they get warm, they fail again.
So i took the truck out for a drive today. It started running really rough again and backfiring. I kept pushing on the gas cuz i needed to make it back home...lol...all of a sudden it threw me back in my seat and took off like a bat out of hell. It came out of running like crap and ran like a champ. I dont get it.
