Spark Plug Wire Differences
Old Apr 6, 2010 | 09:46 AM
Cernicalo1's Avatar
Cernicalo1
Question Spark Plug Wire Differences
Hello Everyone,
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>Could you guys please share your experience with differences between the Motorcraft (O.E.) Spark Plug Wire Set (Part No. WR4109), and the Autolite “Professional” Ignition Wire Set (Part No. 96844) which is sold at some auto part stores?
I ask because although the specs on both parts seem to be the same, since I first took off the original wires on my 1998 2.5L Ranger at about 80K miles, the replacements have not lasted me much more than a year before they start giving me sputtering issues. Granted, the car has gotten older, but still doesn't burn any oil, has proper cylinder compression, etc. So I m thinking about paying the premium to go back to Motorcraft, but wanted to know your thoughts.
<o></o>Many thanks,
Infante
Old Apr 8, 2010 | 08:51 PM
Cernicalo1's Avatar
Cernicalo1
Question 2.5L - Spark Plug Wire Differences
Anyone, Please....
Old Apr 8, 2010 | 09:04 PM
reddog99's Avatar
reddog99
Judging from your previous experience, I wouldn't hesitate to buy the Motorcraft brand. It may be more expensive to buy, but you'll only need to buy one. Many people (including me) have found out the hard (expensive) way that the Motorcraft brand provides a reliable product that is cheaper in the long run than many other brands.
Old Apr 9, 2010 | 09:08 AM
pawpaw's Avatar
pawpaw
I don't rightly know the recipe differences between the two brands, if there is any difference.
But I know the Motorcraft brand has a good reputation, is designed for the double work load our "waste spark"ignition system puts them through & are the right impedance match for our coilpack & specified double platinum spark plugs, so the ignition system is in good electrical tune!!!!
Have you done any ignition system trouble shooting, to determine what the problem is, thats causing the returning "sputterng"????
Are the plug wires breaking down & arcing & sparking to the engine block????
Or is their internal resistance out of spec????
Or is it a plug problem???
Are you using the specified heat range & impedance Motorcraft plugs, gaped to spec????
Or maybe it's a combination of mismatch between ignition system components, if your not using OEM spec ignition system parts ????
Old Apr 9, 2010 | 10:08 AM
KhanTyranitar's Avatar
KhanTyranitar
However all that said, Autolite makes the EO Motorcraft wires, so an Autolite premium should be the same thing. But you can't go wrong with the Motorcraft.
ToMang07
May 29, 2011 10:43 PM
macman85602
15
Jun 1, 2009 10:00 PM
Jet Jockey
1997 - 2003 F150
15
Nov 12, 2008 05:56 AM
sea157
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
15
Dec 28, 2006 02:20 PM
dokniekie
Apr 23, 2004 08:31 AM
