E40D not shifting
Old Apr 6, 2010 | 07:51 AM
kidd_76's Avatar
kidd_76
E40D not shifting
First let me say that this is a great site. I've been searching it for about a week now. And the info and knowledge is very impressive.
I have a 1996 F250 7.3 PSD. Last week the OD light started flashing and it would only shift from 1st to 2nd so i brought it straight home and started searching the web and manuals. Then I changed the filter/fluid and the vss/rabs. I reset the comp after. Now it still won't shift past 2nd but the OD light won't flash. So I can't go get the code read. I also changed out the steering column thinking it might be a broke wire or short in the manual lever. thanks for the help
Old Apr 6, 2010 | 07:59 AM
Cuda_jim's Avatar
Cuda_jim
Have you checked all the electrical connections on the trans. Look for corrosion, fluid intrusion, loose or bent pins/sockets in the connectors.
You'll need to get it on a scanner to determine if the shift solenoids are functioning.
I smell a rebuild in your future....sorry.
Old Apr 6, 2010 | 08:05 AM
kidd_76's Avatar
kidd_76
Thanks for the fast reply. I have looked at the connections. but did not look at the pins just made sure they were still connected. going to look right now. as for the rebuild i was affraid that was gonna be the answer.
Old Apr 6, 2010 | 09:01 AM
kidd_76's Avatar
kidd_76
Checked the connections and seem to be fine. Any idea why the OD light will not flash?
Old Apr 6, 2010 | 09:45 AM
renegade14's Avatar
renegade14
iv got a brand new reman e4od ill sell u its got about 3000 miles on it
Old Apr 6, 2010 | 09:50 AM
kidd_76's Avatar
kidd_76
how much and where you located
Old Apr 6, 2010 | 10:28 AM
renegade14's Avatar
renegade14
well i work at a ford dealership in vermont thats who i got it through i paid 2500 for it id like to get 1000 out of it to help with my swap im in the proses of puting a 5psd in mine i have all the papper work to go with it and it has a 3yr 100,000 mile waranty parts and labor on it i just dont want it to go to waste sitting around
Old Apr 6, 2010 | 02:22 PM
rideracelivemx7's Avatar
rideracelivemx7
holy awsome deal batman
Old Apr 7, 2010 | 07:54 AM
renegade14's Avatar
renegade14
yeah it is i just want sumone to get use out of it
nick_ct_203
24
Jan 14, 2016 02:22 PM
gpacster
15
Aug 16, 2015 11:01 AM
justespresso66
Jul 19, 2015 03:39 PM
IDIDieselJohn
15
Apr 21, 2015 12:02 AM
IJRoorda
17
May 9, 2012 08:42 AM
