hey guys..
just got a 3 in 1 gauge set-up. boost egt and temp. i have a manual so i wanted to use the temp for oil temp, but where would i put it. i dont want to drill a hole and tap it. is there a fitting somewhere i could screw the probe into? im sure some one has done this. if there is something easier, let me know...
thanks alot
chris
cool...ill try to check it out. is there a plug in it now? do you need to get some type of fitting to make it work or will the sending probe just fit in?
thanks alot
chris
There is a plug in there now.I think it is 1/8 NPT,check it out.I bet you can tell by looking at at.Depending on what size your probe is you may need a bushing.
thanks guys...where exactly is the plug...on top of the housing, to the side of the housing...i didnt get a chance to look at it yet, its wet here...ill wait till i get home, but i want to make sure im looking for the right thing.
thanks again
chris
