Carb and Intake?
Old Jan 27, 2003 | 02:00 PM
Racerdave's Avatar
Racerdave
Carb and Intake?
Ok I had a simple Q for all of you who have Edelbrock carbs on your trucks. When I buy my 600 cfm performer, is it a good idea or a waste of $ to buy the performer intake? I heard the dino tests that were done to my friends truck with the stock intake on and the performer intake werent much different? Is it worth the money or no? Also whats the best Cam for my little 302? And remember I want it to sound and perform optimal.
Old Jan 27, 2003 | 03:30 PM
Billy Freeman's Avatar
Billy Freeman
Carb and Intake?
Even if you do happen to have a stock 4 barrel manifold for that engine you will see a major improvement with the Edlbrock manifold and the difference is definately enough to see on the dyno. The manifold will allow the engine to breathe enuogh to use the potential of the 600 carb. This will allow the maximum ammount of fuel to flow through your heads as possible. For the cam I would condider the tranny-Manual or Auto? If manual than you would want a cam that gives more power in the upper RPM range where the greatest potential is with your 302 especially with this top end set up. I would suggest a comp cams 268/268 duration cam.
ryanwiss
May 13, 2013 01:43 PM
lud04X
Jul 13, 2007 02:56 PM
Truckmano5
15
Sep 17, 2005 06:36 PM
dk5122
Mar 2, 2003 01:09 PM
51truck
Aug 1, 2002 04:44 PM
