4 link question...
Old Apr 4, 2010 | 02:43 PM
freakboy's Avatar
freakboy
4 link question...
I wana do a triangulated 4 link on my truck 2wheel drive 1978 well i have a question here about it... ive seen triangulated 4 links done alota different ways.... but my question is should the lower bar be parralell with the frame rails or should it be angled? i was gona have the upper bars goin off the pumpkin and go outward should there be a specific angle i should try to shoot for or will anything go? i also heard the lower bars should be about 70% of the upper bars... again is that true?
Ill be using some DOM tubing not sure of the size yet mabey 1.25 or 1.50 not exactly sure on what thickness i should go with yet... and the brackets are gona be all made from 3/8th steel.. not exactly sure if i will use heims or bushings.. im kinda going twords the bushings more cause i heard the heims will tend to kill themselfs.
Any input on any of this will be greatly apreciated! thanks ahead of time!
oh yeah i will be doing coil over with this.. the main pourpose is a daily driver street truck BUT NOT SLAMED!
Old Apr 5, 2010 | 02:54 PM
HIO Silver's Avatar
HIO Silver
Contact Ballistic Fabrication. They've got everything you'll need.. brackets, bungs, & Heims. I recommend at least 3/16 wall DOM for the link bars.
Uppers should be split at 30 degrees or more from centerline. Why don't you use an adjustable front mount for the lower links?
Old Apr 5, 2010 | 03:35 PM
freakboy's Avatar
freakboy
I didnt think of makin a adjustable mount.. ill have to look into that then.
Trey_Morgan
19
Jul 1, 2014 03:00 AM
rollinblackcloud
Offroad & 4x4
Mar 9, 2014 09:02 AM
oreocreaming
Nov 29, 2010 06:42 PM
cobraguy
Feb 8, 2010 08:32 AM
sara_james
Dec 9, 2004 11:11 PM
