Coolant Fluid leaking from my truck
Old 04-08-2010, 08:23 PM
Jayybird's Avatar
Jayybird
Jayybird is offline
Originally Posted by SteveBricks
That's why it was changed
Thats why what "changed"
Old 04-08-2010, 10:11 PM
SteveBricks's Avatar
SteveBricks
SteveBricks is offline
The hot fill spec....it was changed to the minimum line from the maximum line to prevent coolant from being puked out of the bottle.
Old 09-07-2011, 09:59 AM
dbcrowell's Avatar
dbcrowell
dbcrowell is offline
There's that old style EGR cooler hose to consider also, though it usually makes itself known by leaking down the back of the motor. Do you by chance have your truck parked with the nose downhill?
I have seen this issue this past weekend, is there anything I should do to remedy?
Old 09-07-2011, 06:14 PM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
So, you are seeing the Orange EGR cooler hose leaking?
Old 09-08-2011, 08:08 AM
dbcrowell's Avatar
dbcrowell
Actually, I have seen a leak from the back of the engine falling off the tranny bell housing on the right and left side. It is yellow green coolant. I cant see where it is starting from without tearing into it some. I was parked with the nose sligtly downhill after pulling TT. Only appears when engine cools down (no apparent leak under pressure as we drove home on Monday with no change in coolant level or temperature warnings). Still leaking about 2-3 tablespoons (just a guess maybe less) but only overnight.
diesel 04 X
03-27-2024 03:12 PM
Sullid01
12-22-2014 11:32 PM
ssg510
Modular V10 (6.8l)
04-18-2012 10:01 AM
Tampa250
03-08-2012 07:52 PM
CowboyBilly9Mile
12-04-2004 04:12 PM
Quick Reply: Coolant Fluid leaking from my truck
