Oil & Lubrication
Motor Silk additives
Old Jan 27, 2003 | 01:46 AM
DeKuma's Avatar
DeKuma
Question Motor Silk additives
Has anyone ever heard of these products? Supposedly use Boron to create a crystaline barrier on engine components. Supposedly better slickness than PTFE due to its submicrometer size structure and interlaced crystalline. They claim that one treatment is all you need for the life of the engine since any H2O vapor inherent in the engine helps to reinforce the crystalline structure so it is constantly renewing itself.
I talked with several people who have used it and the claims I am getting are an average of 20% fuel economy increase.
I picked some up today at the Seattle International Boat show for a song, compared to the regular $30 price. Just not sure if it is what they claim it to be. It is new to the US, and so far has only one distributor................
Motor Silk
Old Jan 27, 2003 | 06:31 AM
jschira's Avatar
jschira
None of these additives has ever been shown in independent testing to do anything special.
GM, Ford, Briggs & Stratton have all tested these additives. All 3 found nothing. All 3 recommend against ANY oil additive.
Old Jan 27, 2003 | 07:05 AM
Bob Ayers's Avatar
Bob Ayers
Mercedes also does not recommend any oil, or fuel additives
in their gasoline, or diesel engines...I found this out when
inquiring about using a diesel fuel additive to lubricate
the injector pump, because of lower sulfur content in diesel
fuel. Mercedes response was NO, they went on to say that
the design of the injector pump in Mercedes diesels do not
rely on the fuel to lubricate them...
Old Jan 27, 2003 | 12:40 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Okay, I can see where the conversion to boric oxide will arrest corrosion. Similiar to how a rust converter like Conquest works to convert active red rust to an inhert black oxide.
But who has a rusty engine in the first place? I mean I have a 50 year old farm tractor that has been sitting outdoors all it's life. Everything inside the engine is clean and shiney. (I inspected it with a boroscope, but that's another story.)
Perhaps for marine gearboxes that get contamination from seawater, this may have some merrit. But for automotive engines, I just can't see the use. I don't believe there is any auto mfgr that will recommend the use of any type of motor oil additives.
Besides that, you are NEVER going to convince me to put Boric Acid into my engine!
Scott
Old Jan 27, 2003 | 10:16 PM
skoop's Avatar
skoop
You should have kept your song.
Old Jan 28, 2003 | 06:31 PM
rgiles's Avatar
rgiles
I wouldn't be so quick to throw out Motor Silk as "Snake Oil" just yet. Supposedly Boron can reduce wear by up to 90% and Volvo is running a 1,000,000 test with a Boron based additive. Only one treatment is required to last over 100,000 miles according to what I've read. Maybe it's a breakthrough, and only time will tell. I'm pretty sure that car companies wouldn't be excited about their engines lasting 1,000,000 miles so it would be unlikely to get their approval
I would be willing to run it in a vehicle as an experiement, but I'm not crazy about shelling out $30 for it.
Old Jan 28, 2003 | 07:25 PM
DeKuma's Avatar
DeKuma
I paid much less than $30 for both the engine and tranny treatments. Only time will tell whether it works or not. I will let you know what I find out, since it is already in the vehicle. If I can get my vacuum/timing/crab problem figured out now, I would be a happy man!
Old Jan 29, 2003 | 01:16 AM
horsepuller
FTE Emeritus
>I wouldn't be so quick to throw out Motor Silk as "Snake Oil" just >yet.
Good point rgiles. Perhaps zinc was looked at with the same scepticism before it was adopted as an additive by the oil companies.
Old Feb 7, 2003 | 12:00 AM
BigMattXXL's Avatar
BigMattXXL
Rgiles- I heard something about the Volvo million mile test. I'd be interested to see the results.
Keep us posted!
XXL
Old Feb 6, 2005 | 07:54 PM
Fordcr's Avatar
Fordcr
ok, any updates on this product?
Old Feb 6, 2005 | 08:13 PM
GeoW's Avatar
GeoW
Wink
Good luck with them crabs. Pesky little fellers ain't they...
GeoW
Old Feb 7, 2005 | 10:25 AM
DOHC's Avatar
DOHC
Boron is a good multi functional additive . Theres info on it at RTVanderbilt.com who is a maker of additives for motor oil formulations .
Thing is , some of the oils out there already have plenty of boron in it and when you do normal oil changes your replenishing it anyway .
Citgo
Pennzoil
Mobil1
Havoline are but a few who uses it . Why pay for it elsewhere when it's incorporated into the cost of these oils ?
Old Feb 7, 2005 | 10:55 AM
MBDiagMan's Avatar
MBDiagMan
The long and the short of it is that our premium motor oils are so good now that there is just no need and possibly harm to come from additional components.
The additive package in most any modern premium motor oil is a careful balance and the addition of such stuff is not only unnecessary, but may upset the balance of the additive package which could cause more harm than good.
If you will change oil and filter frequently that is just all you need in the oil department to allow for long engine life.
Good luck,
Doc
hollapm
Dec 2, 2016 09:57 PM
twofifty
17
Jul 14, 2016 08:15 PM
DevilDocTater
Feb 19, 2016 10:01 PM
sgauvry
Oct 5, 2015 08:18 PM
ImAGirl
Aug 3, 2015 03:13 AM
