Cleaning engine bay
Old Apr 4, 2010 | 08:37 PM
Fordzilla80's Avatar
Fordzilla80
Originally Posted by FordNFishinLover
I figure i'll just replace it when my transmission goes out
Cheers to that.I'll replace mine when I rebuild the engine.
Old Apr 4, 2010 | 08:46 PM
quality job 1's Avatar
quality job 1
is the seal a 2 piece or 1 piece and once the trans is out what is involved? im use to 1 pc rear mains on my formula and S truck. when ever that seal starts leaking i tell folks to get a sleeve kit just in case the rear main has a groove in the crank. a lil RTV and it slips on and pop the new seal in and put the rest back together.
if the ford is anything like this then it'll be a snap.
Old Apr 4, 2010 | 09:02 PM
greyghost85's Avatar
greyghost85
one piece, yes. i can see holding off it it isnt leaking too badly. my eng is the six cyl, BTW. DK about the V8s
Old Apr 4, 2010 | 11:02 PM
FordNFishinLover's Avatar
FordNFishinLover
My leaks just enough to make it dirty.
But it leaks so little that i rarely see a drop of oil on ground, and my oil doesn't get too low.
Hope i didnt just jynx myself!!
Old Apr 5, 2010 | 06:58 PM
girlwithatruck's Avatar
girlwithatruck
when your transmission (someday far far far from now) goes out i will have already done all the research for ya! this time i'm AHEAD of you on a project!
Old Apr 5, 2010 | 10:09 PM
FordNFishinLover
Hahaha, sounds like ill be talking to you sometime em!
Ya got me on this one. But unfortunatly my transmission has been acting up. I fear the worst is bound to happen in the future.
Old Apr 13, 2010 | 10:31 AM
Grubbworm's Avatar
Grubbworm
When I clean the engine bay in any of my vehicles, I use Westley's Bleach White. I find that it works wonders. Warm the engine first, then spray on Westley's Bleach White. Let it soak in for a few minutes, and wash off with the hose. Or, you could use the car wash high power sprayer to wash off the Bleach White. Try it, once you use it, you'll love it.
Old Apr 13, 2010 | 11:14 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Incredible Pink
This is NOT "Pink Stuff", This is "Incredible Pink"... Two different products, Pink Stuff is water compared to Incredible Pink!
Try it, you'll like it, you'll never know how you cleaned anything without it.
WARNING!!! DO NOT ALLOW IT TO DRY!!!!!!
I use it in a Yard sprayer FULL strength, use before water wetting, soak it down good, keep it soaked and the grim will just run away, Thick grim may need a little disturbing to allow it to soak in, once the grim is all loose water rinse THROUGHLY!!!
You will be surprised!
And the cool part, It's non-toxic, biodegradable, non-flammable.
-Enjoy
fh : )_~
Old Apr 13, 2010 | 08:52 PM
greyghost85
where do you get Incredible Pink?
Old Apr 13, 2010 | 09:01 PM
Fordzilla80
Mine is too.But it might just be low on fluid.I haven't moved it in awhile,so I've neglected to check it every so often.I still need to replace my lines.
Old Apr 14, 2010 | 12:44 AM
Festus Hagen
Methanoholic
Click on the "Incredible Pink" link embedded in post #23. (Or one of the ones in this post)
I have no affiliation with these people, I just love their Incredible Pink, Stuffs awesome.
BTW: Local peeps can take their empty jugs back and they will re-fill them for less $$$.
-Enjoy
fh : )_~
drewduncan15
Mar 30, 2014 06:52 PM
drewduncan15
22
Jan 26, 2014 12:11 AM
drewduncan15
Jan 25, 2014 12:29 AM
drewduncan15
Dec 8, 2013 01:09 AM
