Sponsored by: Real Truck
E4OD 4R100 swap
Old Apr 3, 2010 | 11:25 AM
patndhat's Avatar
patndhat
E4OD 4R100 swap
I have a 4r100 4x4 trans and I want to put it in my sons 91 replacing his e40d can I make it work. What problems will I face. Can it be done?
Old Apr 3, 2010 | 12:40 PM
mhoefer's Avatar
mhoefer
What is the donor vehicle, transplant vehicle ie 91 what, bell housing match, i think you will have a hard time cause 4R100 is more electronic so needing a computer to run the new system could be problematic.
Old Apr 3, 2010 | 12:58 PM
patndhat's Avatar
patndhat
it came out of a gas engine one ton '02. I understand that the older computers should run it just not the other way around because the newer ones rely on speed sensors to shift. What I am asking is if it will bolt up to the 460 and brackets shifter and what not has anyone made this swap before? What problems were encountered?
Old Apr 3, 2010 | 03:27 PM
suzuki0702's Avatar
suzuki0702
4r100's were never on a 460 so i doubt the bellhousing will bolt up..
Old Apr 3, 2010 | 03:56 PM
mhoefer's Avatar
mhoefer
nope, 460 different, 4R100 has integratd bell housing, different pattern. Sorry.
jerrytown2001
16
Dec 27, 2019 05:24 PM
ml_nelson
Oct 28, 2013 08:09 AM
bduemig
Aug 25, 2013 05:53 PM
71cc
May 15, 2012 11:49 AM
Drober6473
Feb 14, 2010 12:56 AM
