calling all super camper specials
#887
Look on the B pillar below the door striker plate for the white Safety Standards Certification Label. It was originally glued on.
The Warranty Plate is located on the face of the left door below the latch.
clems78: There is no such thing as a Super Camper Special after 1976, as Ford dropped 'Super' from the name at the end of the 1976 model run.
#889
my 89 f-250 with 302 was computer - located under fuse panel on firewall do yourself a favor dont buy a reman for 300 like I did the first time truck ran the same way would only start on ether and run poor no power went to junk yard for $50 computer truck running perfect 2 years just make sure same (auto,overdrive,motor,) let us know
#894
#896
1973/79 F350's on the 140" wheelbase: 1973/76 Regular Cab Super Camper Special / 1973/79 Regular Cab Trailer Special / 1977/79 Regular Cab Camper Special.
Ford dropped Super from the name at the end of the 1976 model run.
1973 only: D3TZ-16720-W .. Super Camper Special Emblem, right/left is the same.
1974/76 only: D4TZ-16720-D .. Super Camper Special Emblem, right/left is the same.
1977/79 only: D7TZ-16720-AD .. Camper Special Emblem, right/left is the same.
Race Track (R/T) side mouldings were introduced in 1977. Came standard equipment on F100/350 Ranger XLT's in 1977, F100/350 Ranger XLT's and Lariats 1978/79.
Bronco's were also available with R/T's in 1978/79.
These mouldings were very popular when introduced. People that owned plain jane 1973/79 Customs and Rangers waltzed into the parts depts, bought all of the mouldings, installed them on their trucks.
What are the outward appearance differences between 1973/75 and 1976/77? The grille inserts are the same 1973/75, 1976/77's are slightly different. The grille shell is the same 1973/77.
1973/76 Stylesides have exposed fuel caps, 1977/79's have fuel doors.
"Fish mouth" grille introduced in 1978.
1973, 1974's before serial number T80,001: The parklamps and taillamps have separate lenses, screws retain the lenses to the metal bodies, the sockets are swagged into the bodies.
1974 from serial number T80,001, 1975/79 have one piece molded plastic parklamps and taillamps. The individual sockets twist into the lamps.
The one piece F100/350 taillamps are the same as 1975/91 Econoline and 1978/79 Bronco. The only difference is a seal that peels off.
Originally Posted by 74 F350 SCS
The 73-75 models have a total classic look and are sweet.
#897
Wow lots of wasted time typing over a comment that had nothing to do with you. So thanks for taking a light hearted jab at other year trucks out of context and turning into a very educational but unnecessary show of your vast knowledge of scs and all things ford truck. All hail the king of the ford truck info stuff!!!
