head removal question
Old Apr 2, 2010 | 09:01 PM
spudgunman's Avatar
spudgunman
So I have the engine ready to remove the heads I was reading in the book that I need to "loosen rocker arm stud nuts" so they can be rotated to the side
Looking at my heads, the rocker is on the fulcrum which is a large "pillar" that is formed as part of the head (aka I don't seen any thing that is movable that I can rotate)
and when it says remove push rods do they just pull out? (I know to keep them in order)
so Q: how do I properly get to the head bolts that are in the rocker area
Q2: how do I pull out the push rods when they seem to be very attached to the rockers by compression or what not
engine=78/400/4x4
Old Apr 2, 2010 | 09:13 PM
Furyus1's Avatar
Furyus1
Just loosen the bolts that hold the rockers on - they do rotate once the bolts are loosened far enough - the rods just lift out.
Old Apr 2, 2010 | 09:14 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You loosen the rocker arm nut and then rotate the rocker arm out of the way. Or just go ahead and remove all of them keeping them in order.
Josh
Old Apr 2, 2010 | 09:16 PM
cdawley4's Avatar
cdawley4
I removed the heads once from an engine that was in a 77 Ford Truck. If I remember correctly, they just pulled off, once I got the bolts out. I also remember having to use a flat screwdriver to pry them as I tried to remove them as well. Hope that helps.
If anyone disagrees, please let me know, as I am getting ready to rebuild a 351M that is on an engine stand.
Old Apr 2, 2010 | 09:37 PM
spudgunman's Avatar
spudgunman
awesome thanks
also in chilton they have this long "put cyl 1 to TDC" then put on intake 1 and exaust1 followed by exhaust 3
Q: do i need to follow that or can I just rotate them back in place and tighten the rocker fulcrum bolt to spec and be on my way?
Old Apr 3, 2010 | 12:39 AM
spudgunman's Avatar
spudgunman
sorry that last post was about how to put the rocker's back into place once I rotate them can I just put them back and make em look good or do I need to follow the setup procedure that I see in the book?
how do I put the rockers back once I rotate them, since I only need to move like 4 of the rockers do i need to follow this whole process to put the rockers back in? do I need to loosen them all and start the process? or just tighten the ones I pulled back in?
Old Apr 3, 2010 | 08:12 AM
79 f350ts's Avatar
79 f350ts
on pedestal mounteed rockers , just reinstall and tighten to spec
Old Apr 3, 2010 | 10:57 AM
spudgunman's Avatar
spudgunman
awesome thankyou
