Jack Points for 2008 E250?
Old Apr 2, 2010 | 07:23 PM
jimbofish's Avatar
jimbofish
Hello, long story short, I can't seem to find the jack points for my vehicle.
I do not have an users manual.
I need the jack points for the front.....I would rather ask instead of break something...
I found out the rear jack points, just need the front now.
REAR
FRONT
Old Apr 3, 2010 | 01:40 PM
gearloose1's Avatar
gearloose1
Front:
"under the radius arm at the I-beam"
Rear: DO NOT JACK at Pumpkin
See:
https://www.ford-trucks.com/forums/6...ints-e350.html
Old Apr 3, 2010 | 04:14 PM
Fox Fader's Avatar
Fox Fader
Originally Posted by gearloose1
Front:
See:
Wow, I read that thread and find it hard to believe someone rotated their tires and they won't do it again.
OP,
As said, don't jack under the diff. It'd be easier, but not recommended here, but you can get all four off the ground at the same time with a good floor jack and four stands. You can do it with two stands just be careful jacking up front.
Old Apr 3, 2010 | 09:57 PM
jimbofish's Avatar
jimbofish
thanks for ya'lls replies. I just did one tire at a time.
Anyways I got it done safely.
I also happened to get my hands on a instructions sheet, I'll try to find a scanner and upload it here for everyone else as well that may be having the same problems.
Old Apr 4, 2010 | 08:02 AM
Fox Fader's Avatar
Fox Fader
Glad you got it done. Yes, please do get a sheet up, we need all the help we can get here. Info is a little thin on the E.
Old Apr 5, 2010 | 06:18 AM
shorebird's Avatar
shorebird
Link to owners manual (Dial-up warning 2.57 MB)
http://www.motorcraftservice.com/pub.../08ecoog3e.pdf
Page 206 and 207 for jacking instructions.
Jack rear axle between the u-bolts holding the springs to the axle.
Front axle jacking point:
Place the jack under the pin on the front surface of the front axle.
jayellcowen
1983 - 2012 Ranger & B-Series
Jul 26, 2009 08:04 AM
Glockem45
Apr 28, 2009 06:05 AM
fiveohpoepoe
Apr 26, 2009 12:45 AM
skunk250
Apr 23, 2009 04:17 PM
TheBigBee
Mar 2, 2009 08:05 AM
