Intake selection
Old Apr 2, 2010 | 04:01 PM
newkguyontheblock's Avatar
newkguyontheblock
Intake selection
I'm building a 302 with .030 ovebore to put into an older ranger.
Afr 165 and a 280H camshaft.
What intake would you suggest. I want to keep it EFI.
It's going to be a road setup with the occasional mud run.
Old Apr 2, 2010 | 09:01 PM
b_eastep's Avatar
b_eastep
the stock 5.0 truck intake is a pretty good intake. several aftermarket intakes use the stock truck lower which is diff than on the cars such as a mustang. i would just look for an aftermarket upper that uses truck lower if you are dead set on a new intake. i wouldnt mess with it myself if i was you.
Old Apr 2, 2010 | 09:32 PM
Conanski's Avatar
Conanski
A Performer or GT40 would be a good choice.
Old Apr 3, 2010 | 08:15 PM
newkguyontheblock
OK thanks I'll look into those.
What would you do to increase mileage? cold air intake, turbo?
The engine is not even built so I don't know what kind of mileage it's gonna do, but it's better to know in case later I want to keep modifying it.
Old Apr 3, 2010 | 10:21 PM
Conanski's Avatar
Conanski
Originally Posted by newkguyontheblock
What would you do to increase mileage? cold air intake, turbo?.
Ah.. no. If you want milage build the motor to produce as much low rpm TQ as possible, and on a 302 that means your head and cam selsection is all wrong.
Old Apr 3, 2010 | 11:10 PM
newkguyontheblock
No i'm not aiming for mileage.
I'm was just wondering what ways there would be to inrcease it.
Old May 19, 2010 | 08:28 PM
MrNord's Avatar
MrNord
Hi,
I have a 1995 F-150 4X4 that I have built with the following:
K&N cold air intake, Permacool Cool pack electric fans, Ford Racing E303 cam w/4* advance, Ford Racing S/S headers, all stainless dual exhaust, Edelbrock 5.0 Truck Performer intake manifold, Accel U-Groove plugs, 9000 series wires and ignition module. All ordered from summit Racing.
You asked about gas milage...I currently get about 8-10 MPG... as long as I stay out of the throttle.
MrNord
Old May 19, 2010 | 10:34 PM
Conanski's Avatar
Conanski
WOW.. that's terrible... sorry. What is the rest of the combo... trans, axle gearing, tire size?
Old May 19, 2010 | 11:05 PM
MrNord's Avatar
MrNord
4R70W Trans, 31X10.5 Tires and I'm Guessing whatever the factory gearing is...and I DO have a lead foot and it's not a "Daily Driver".
I'm still tinkering with the timing and throttle, oh, I also have a March model 1000 5.0 underdrive pulley kit I had to put a bushing under the Alternator pulley. The changes I've made have moved my power band up by about 500-1000 RPMs (I'm guessing, I have no access to a dyno). It's not real fast off the line but will put you back in the seats when it hits second gear.
MrNord
Old Jun 6, 2010 | 08:00 AM
385seriesHemi's Avatar
385seriesHemi
Producing efficient combustion by conditioning the combustion chamber surfaces and correct spark plug heat range will improve fuel mileage. The stronger and more consistant your flame travel is, the more power you will make. A more free flowing intake filter will be a start for a cooler air charge.
What is the maximum rpm you will be seeing with this engine? You could get by with a 2V carburetor too.
Old Jun 7, 2010 | 09:44 AM
fordeverpower's Avatar
fordeverpower
the 302 should have never never ever been put in a truck. Just about anything to improve power raises the powerband and loses low rpm torque and 302 seriously lack torque with only 3 inches of stroke. I do like the afr 165 heads but its not going to be an ideal combo.
mainman
2004 - 2008 F150
Dec 31, 2009 08:11 PM
Bigblockexplorer
Feb 2, 2008 02:09 PM
lud04X
Jul 13, 2007 02:56 PM
fordeverpower
Oct 31, 2005 03:04 AM
fordeverpower
Jul 1, 2005 05:17 AM
