Power Steering Flush
Old May 11, 2006 | 12:53 PM
njf207's Avatar
njf207
Smile Power Steering Flush
How Do I flush the power streering system on a 98' Exploer 4.0 4x4.
Old May 11, 2006 | 02:14 PM
bdmcdonald's Avatar
bdmcdonald
You could wait for a hose to break, that'll do it. Or you can get a suction tool and remove the old fluid and add new PS fluid. Or you could remove the return hose and run the engine for a bit to pump out the old fluid. Just don't run it dry for more than second or two.
Why do you want to do this anyway?
Old May 11, 2006 | 02:18 PM
njf207's Avatar
njf207
The fluid is old and looks creamy and kind of thick. The steering is feeling a bit heavy also. I have some loss of centerline feel also. So insted of having some do this I thought this was something I could do on my own.
Old May 11, 2006 | 03:30 PM
srercrcr's Avatar
srercrcr
Why?
Because have you priced rack and pinions, not to mention PS pumps?
I flush the PS on all my cars annually.....cheap insurance.
Old May 11, 2006 | 03:31 PM
ajguzik's Avatar
ajguzik
I've been thinking about flushing mine. It looks like it would be relatively simple to drop a line off of the cooler located below the radiatior. Add a line into a jug of new fluid and let the old go to a waste container. Let it run until it comes out like new. Is it OK to use regular Mercon ATF, or do you need special fluid?
Old May 11, 2006 | 03:42 PM
87 XLT's Avatar
87 XLT
When I flushed my 87 I made the mistake of starting it up, and the pump ran dry in about one second.
Hate the sound the pump makes when that happens..
I finished flushing it at cranking speed by tapping the inertia switch on the floorboard until the button popped up. This worked MUCH better.
Old May 11, 2006 | 03:58 PM
bdmcdonald's Avatar
bdmcdonald
You should use power steering fluid. Look it up in the owners manual or a shop manual. Make sure your unhooking the Steering not the transmission cooler!
"Phatman"
Aug 3, 2015 07:26 AM
plummer
1997 - 2003 F150
Mar 12, 2015 09:03 PM
rattleNsmoke
Jan 14, 2015 09:03 PM
bigred66
Jun 24, 2014 07:51 PM
beachcamperf250
May 21, 2014 08:09 AM
