EFan installed..
Old Apr 2, 2010 | 04:57 PM
Bayer-Z28's Avatar
Bayer-Z28
Originally Posted by skyfox10
I think that it would probably just be pest to install a relay from the ignition power. So it just powers off when the ignition is off.
Yes and no.. Just one additional wire running across the engine bay and ANOTHER relay under the hood to add to the clutter. I really don't feel like adding any more relays.. I only used 2 for the head light fix, just tee'd the driver's side off. It still gets 13v.
Old Apr 2, 2010 | 05:22 PM
skyfox10's Avatar
skyfox10
That was the nice thing about my old truck. My dad had it new and installed a back of relays on one of the inner fenders for all of his ham radio equipment. He equip migrated to his new truck and i was left with the relays.
Old Apr 3, 2010 | 05:29 AM
lew52's Avatar
lew52
I use one relay , wired so it comes on with the ignition on , then have a toggle switch to turn the fan off . Also have a kill switch wired to the coil so i can shut off the ignition & still run the fan .....Lew
Old Apr 3, 2010 | 09:37 AM
daveyboy1's Avatar
daveyboy1
I am going to use a temp sensor, then wire in a by pass toggle switch still havent desided if i am going to use batt power or KO power. I would like to be able to cool the truck down at the race track as much as possible.
Old Apr 3, 2010 | 10:42 AM
lew52's Avatar
lew52
Yeah thats what i use mine for , its nice to be able to shut the fan off when you make a run at the track or on the street when you don't need it & be able to run the fan with the motor off to cool down , i use the kill switch in case i have to shut the motor down i just hit the switch ....Lew
Old Apr 3, 2010 | 10:46 AM
SaikotikGunman's Avatar
SaikotikGunman
I like this idea too. But I would worry about someone else driving the truck and bumping the switch or something, then (well, you know what would happen)
Why the heck would you let anyone else drive your truck!?
I'm afraid someone will and then I'll have to and send them to meet .
Old Apr 3, 2010 | 01:33 PM
86f350's Avatar
86f350
Im also looking into doing this with my 89 F250 4.9l. Keep us up to date on your MPG gain/loss. Also what were you averaging before you installed the e-fan ?
Old Apr 3, 2010 | 03:05 PM
94MustangGT's Avatar
94MustangGT
Nice work.
Looks like a Taurus fan. If so, do you know if it came out of a 3.8 or 3.0?
Old Apr 3, 2010 | 07:22 PM
l67cooled's Avatar
l67cooled
Bayer, That's pretty weird your fans are coming on without your coolant temp's being up to desired temp you chose. I'm willing to bet your switch is faulty. Like I said I have the same switch and no relay and have no issues with mine turning on if not hot enough.
I'm in the process of rewiring my fan setup. I have a new two speed 16'' fan. I'm wiring the low speed up to a t stat that will switch on at whatever temp I chose. Then I'll have a switch inside that will be able to switch from auto low, off, and full time high.
Old Apr 3, 2010 | 08:16 PM
Bayer-Z28's Avatar
Bayer-Z28
Originally Posted by 94MustangGT
Nice work.
Thanx bud..
The fan came out of a Mercury Sable 3.0. ... Same thing.. yeah..
I was averaging 12/23 at best. I think I'll clock my city mileage this week. I typically fill my tank three to four times a week.
Old Apr 3, 2010 | 11:33 PM
94MustangGT
^That's right, I remember you saying that now.
I'm real interested to see how your MPG figures turn out. I looked into doing an E-fan swap last summer, but ran out of time. Maybe this summer....
Keep us posted.
Old Apr 4, 2010 | 11:02 AM
Bayer-Z28's Avatar
Bayer-Z28
^ I was watching Xtreme 4X4 this morning and Eean said that they did an E-Fan swap on a Cummins Dodge and only picked up about .15 MPG which equates to an extra 3 extra miles per tank. Prolly not gonna be a big change, but the power gain was worth it. That thing really didn't need a fan running all the damn time.
Old Apr 4, 2010 | 08:36 PM
  #28
daveyboy1's Avatar
daveyboy1
Started installing my fan today
Old Apr 4, 2010 | 08:40 PM
  #29
86f350's Avatar
86f350
Which fan did you use ? The dual fan or the single fan ?
Old Apr 5, 2010 | 09:22 PM
  #30
Bayer-Z28's Avatar
Bayer-Z28
Got a high idle when the truck gets good and WARM now.. Not hot.. Have the fan set to come on at the "A" on NORMAL. I got a temp probe thing, I'll have to shoot it tomorrow to see what the temp is. I figured that the EEC sees the temp getting high and raises the idle thinking that the belt fan will cool it off.
