I have a buddy with an 03 6.0 with 100K on the clock. They have had it for a while and its had the EGR replaced once and atleast one turbo cleanin. Here lately since the weather has turned nice the truck has started running rough. After it starts up and sits for a second it runs rough idles way down and up a bit them immediately goes to a high idle. Also when she presses the pedal down like a woman(no offence) it won't go any where or it just barely moves. Its not throwing any codes either
Not very familiar with the 6.0s I was just wondering what it could be. Also the truck has had an Edge evo on it since 50K
He said his edge, I am going to get AE hooked up hopefully saturday. I haven't heard the truck run so I don't know. Would the EGR be fine after it warmed up?
If it runs good once it warms up there are three things that come to mind first egr valve (that one probably won't matter if it is warmed up or not), injector sticktion, and ficm problems. Look in the tech folder of this section for a good write up on checking/cleaning the egr valve, and checking/repeairing the ficm. And of course the ae will show alot more about the problem than the edge will. One thing to remember about the ae when checking the ficm voltage it won't read write if the voltage is to low. So if it shows anything other than 48 volts I would check it manualy with a multimeter.
I agree with Sandman, try unplugging the ICP sensor during concern to see if it goes away. Most likely given that it is a 2003, the sensor may be oil-fouled. Its on the pump cover at the back of engine under turbo, can be accessed over transmission from underneath.
Well the truck is just drove by the with I am sure it isn't drove hard and like he said she just gets in now mashes the pedal and it won't move. Does anyone have a picture of the ICP sensor on these trucks? Just unplugg it and see how it does? It gets drove every other day but a decent amount of short trips
Well got over there late and didn't have AE will be back next week I DO have a video though. Login | Facebook
It stumbled when it started a few times kinda like a light romp. Then it kept going on that sound cycle kinda like an EBPV on a 7.3L and it had NO power at all. SO I am guessing the good ol 03 turbo is sticking up bad at 100k?
