Got a vibration?Read
Old Apr 4, 2002 | 10:10 AM
SNIPER 222's Avatar
SNIPER 222
Hello there i have a 2000 Expy XLT 5.4
i took it into the shop for a slight
vibration that occurs around 40mph.
The dealership has had my vehicle for 12 days now
and they finally found the problem,first they
replaced the tires didn't fix it
replaced the drive shaft didn't fix it
overhauled the tranny didn't fix it
balanced the front shafts din't fix it
rebuilt the entire rear axle didn't fix it
finally found the front shaft in the transfer
case was warped so now they are replacing the
entire transfer case so now they will have my Expy
for another 3-4 days waiting for parts
Hope this helps if you have a shutter or a vibration
while driving. give me your feedback on this situation
SNIPER
2000 EXPY 5.4 XLT LOADED
FIREFIGHTER
BLESS ALL OF OUR FALLEN HEROS
Old Apr 8, 2002 | 09:34 AM
boffah's Avatar
boffah
Well, did that finally fix it??
Old Apr 8, 2002 | 10:03 AM
SNIPER 222's Avatar
SNIPER 222
Well i am happy to say that the Expy
is back on the road replacing the transfer case
fixed the vibration - the shaft was warped in
the transfer case
Old Apr 8, 2002 | 11:48 AM
98expeditionXLT's Avatar
98expeditionXLT
Did you ever find out what caused the warped shaft in the transfer case?
Old Apr 8, 2002 | 12:14 PM
SNIPER 222's Avatar
SNIPER 222
They could not give a good answer why
the shaft was warped i think it was like that from day
1 and just got worse as it got more miles
Old Apr 8, 2002 | 12:49 PM
jfuent's Avatar
jfuent
Old Apr 17, 2002 | 12:17 PM
sgou's Avatar
sgou
HELP!!!! Did you experience something similar to this?
I have a 99 Expedition 5.4 EB with 41k and for the last 1000 miles i've noticed a shudder, vibration, rough "clunking"(lack of better word) when
I accelerate. It is especially noticeable when the car is under load pulling a grade. I've noticed this at speeds usally higher than 40-45MPH
but especially noticeable when going 65-75MPH. I brought it to my dealer/service dept. and they first thought it was related to the ignition coils
( no codes stored...so they determined that was not the cause), then the next step they replaced the fuel filter/ fuel pump/sender. Problem still
present. Then they started looking at the transfer case and changed the oil in the transfer case and reset the GEM module/computer.
Problem is still present!
Help!!!, has any one else experienced this same problem with their 99 Exped 5.4 EB? I have thrown $500 at this problem since the car is out
of warranty and my ford powertrain warranty does not cover this area.
thanks for any insight into this problem
Old Apr 17, 2002 | 02:40 PM
adelyser's Avatar
adelyser
My first look would be at the driveshaft U-joints and the transmission/motor mounts.
Old Apr 17, 2002 | 04:49 PM
buzzard's Avatar
buzzard
Wow, very hard to diagnose, but it could be an unbalanced driveshaft in addition to other drivetrain related.
TKegs763
22
May 9, 2017 09:33 PM
passthegaff
Mar 13, 2017 08:21 PM
sniper7369
Jan 23, 2014 09:05 PM
SNIPER 222
Feb 19, 2008 01:44 AM
ronmoon
Feb 13, 2004 09:51 AM
