I have a post running in the audio session but I have not received a response to this question and thought I would ask it here. Did a search but could not find the answer.
2004 F250 - I'm looking for VSS wire. From my research it a grey/blk stripe wire going to the PCM. I tap in to what I thought was the wire grey/black wire at the PCM but it not reading the correct MPH. When I am driving 60 MPH the GPS on the Nav unit thinks Iam driving 16MPH. Where did I go wrong.
It would help if you posted what nav unit you are using. Anyway, there's a possibility you have tapped the wrong wire or the unit needs to be reset (can't tell as I don't know what unit you are using!). Here's a link for you....
[QUOTE=rotun;8709732]It would help if you posted what nav unit you are using. Anyway, there's a possibility you have tapped the wrong wire or the unit needs to be reset (can't tell as I don't know what unit you are using!). QUOTE]
It's an Eclipse AVN 5434 I believe, its a older unit purchased back in 2006. currently i am tap in at the PCM. I will look behind the gauge cluster.
If this unit was previously installed in another vehicle you will have to do a reset on it after the vss is hooked up...it needs to relearn the speed pulse for the new vehicle. Check the user manual re: learning strategy for the gps speed pulse / master reset.
Sounds like you have the right wire. The VSS signal goes to many different components (PCM, ABS, instrument cluster, overhead console, 6 disc CD, wipers)etc. It's the same color scheme throughout. I agree with rotun, it's gotta be something in the HU.
