Fuel filter at tank?
Old Mar 31, 2010 | 09:15 AM
yankeerebel's Avatar
yankeerebel
Does the 1977 model f150 have a fuel filter by the tank in addition to the inline one at the carb?
Old Mar 31, 2010 | 10:11 PM
radar457's Avatar
radar457
dont think they had one at the tank stock. There is a kind of screen in the tank on the pickup tube. Sometimes people put an inline at the fuel tank switch valve. You can put an inline filter anywhere you want.
Old Apr 1, 2010 | 05:17 AM
Zip's Avatar
Zip
On my 75 it is right where the fuel line enters the carb. Kind of a tiny thing. I believe it screws into the carb then the fuel line is connected to it.
Old Apr 1, 2010 | 06:19 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Nope, not on trucks of this vintage.
The fuel filter (as previously mentioned) threads into the carburetor. There are two different fuel filters, with two different sized threads.
The 2V's are the same from 1965 thru the 1980's (D3AZ9155C-Motorcraft FG14C).
There are two different types for 4V's. One is the same as the 2V, one is not the same (D3OZ9155A-Motorcraft FG19C).
1967/79: The fuel sending units (except w/In-Cab tank) have a plastic meshed filter screen (D1AZ9A011A) that slides onto the pickup tube.
The same one (it's 3/8" I.D.) fits passenger cars (except Pinto/Bobcat/Maverick/Comet as it's 5/16"), F100/350's, Bronco's and Econolines thru 1979.
1980 and later is not the same.
Old Apr 1, 2010 | 09:33 AM
yankeerebel
If that pickup screen is clogged with tank debris, will I be able to tell with a fuel pressure gauge at the fuel pump?
My problem is that my truck will start with one pump of the gas pedal and then die only a few seconds later. On the second try, the truck will start and stay running. I thought I might be pulling against a plugged filter. The carb filter is brand new and so are my fuel lines.
Old Apr 1, 2010 | 10:14 AM
radar457's Avatar
radar457
If the tank screen was plugged I think it would show up worse at higher rpm. As for a pressure tester , I have seen them for fuel injected but not sure you can test mechanical pump with it. Could be that when setting the fuel bleeds back through the fuel pump down the line, and when you start it it fires the first time on whats inline above the pump then dies. Second start the pump has to pickup fuel again.
Wheelman55
Aug 2, 2015 02:30 PM
Jamaika
Apr 17, 2015 12:14 AM
grantkat
Aug 23, 2014 01:19 AM
obscurity
Jun 6, 2014 11:17 AM
Blitzing Hernandez
Apr 27, 2014 01:23 PM
