Squeek!!!! and hub Question
Old Mar 30, 2010 | 02:44 PM
RustyTub's Avatar
RustyTub
My 77 f 250 with a NP203 (part time kit) and dana 44 low pinion front and warn hubs is squeeking when I have the hubs locked in. And it doesnt matter if the t case is in 2wd or 4wd.
Also I noticed my drivers side hub only turn half way to the unlock position, the hub still disengages and engages but I ordered a rebuild kit for it any way.
My main concern is the squeek, I have greased all the Zerk fitting even the ones in the U joints but it still is squeeking. I have the truck up at my property and would like to know where I should start. seeing that while it is there I have to work in the dirt and gravel (shop is no where near done) and while it is squeeking I would rather not drive it 20 miles to work with lifts and all my tools. I is also a bummer cause I found a new trail to get to the backside of my property and it is killing me not to try it.
Old Mar 30, 2010 | 03:35 PM
CraigOutdoors's Avatar
CraigOutdoors
Have you pulled the lockers off to look at them yet? If it's not turning all the way, and things are squeaking, then that would be the first thing I'd do.
Old Mar 30, 2010 | 03:59 PM
75F350's Avatar
75F350
Typically when we hear a squeak up front it is a dry u-joint. Yours are greaseable? many are not.
That being said you also have a small bearing inside of the spindle that often gets neglected. This can go dry and will squeak when the stub axle is being turned. This only turns when the front hubs are locked, so this might be your problem.
If your manual locking hubs are not turning all of the way, you must take them apart and find the obstruction.
Often times the inner gear is backwards, and wont disengage. This depends upon which style of lockout you have though.
75F350's Avatar
75F350
Old Mar 30, 2010 | 06:34 PM
RustyTub's Avatar
RustyTub
I am assuming the U joints are old! cause they have little zerk fitting to grease them. I will tear into the hubs tonight and find out what I got going on. they are the Warn Premium hubs
Will I need to have the front on stands to pull the locking hubs off and inspect, As I said before I have limited tools and am working in the dirt were the truck is.
Old Mar 30, 2010 | 06:52 PM
75F350's Avatar
75F350
Nope the lockouts will come right off with only a small allen wrench, snap ring pliers, and a small set of screwdrivers to remove the large snap ring on the hub.
This only takes a couple of minutes really.
Put something on the ground, because this should be a rather clean procedure.
Dirt is not a good thing to have in there.
If you have to grease the inner bearing, you will have to remove the entire hub and pull the spindle though.
This will take a little while. You could spray some water or something in the back side of the spindle. If the squeak goes away after a small dose of water, you know you have found your problem.
Water wont hurt anything, but will lubricate just enough to make the noise go away for a minute or two.
Good way to isolate the problems, or find little squeaks like this.
Old Mar 30, 2010 | 07:52 PM
RustyTub's Avatar
RustyTub
Thanks for the reply, If I have to go into it past the locking hubs I will have it towed to our shop in town. Were I have a couple of lifts and all my tools.
BTW 75F350 I just looked at the pics of your front steering and have to say that is impressive, certainly going to do my steering like that when the time comes!
Old Mar 30, 2010 | 07:57 PM
75F350's Avatar
75F350
Thanks for the compliment. Ive got to say, crossover is the way to go.....
Much luck on your repair.
