1998 Explorer Transmission - reverse shift delay
Old Jan 26, 2003 | 12:26 PM
steverowe's Avatar
steverowe
My '98 has a 5-10 second delay before it shifts into reverse. This delay length depends on how long it has been sitting and doesn't happen all the time while being driven.
Old Jan 27, 2003 | 07:44 AM
Opera House Works's Avatar
Opera House Works
Has had numerous complaints about valve body problems. When I changed the filter on my 97 I found all the valve body bolts loose. These should be torqued to 7-8 ft-lb which is just a good twist. DO IT NOW WHILE YOU STILL HAVE A GASKET. There is a large area next to the low/reverse servo that is unsupported by a bolt where the gasket is prone to failure. Several have reported multiple failures. These double sanwitched gaskets are only 0.008 with a steel seperator plate between. It should be noted that for the older A4LD there were optional double thick gaskets for transmissions that had warped some. As they attempt to take every ounce out of a casting to increase CAFE, warpage is bound to become more common.
Old Jan 28, 2003 | 03:10 AM
jon42's Avatar
jon42
Ive got the 91 A4LD.apparently they havent yet cured this ailment on the assembly line .All thats required for the fix is redrilling a hole in the programing plate from the 1/16th to 1/8thit should be.I had the same problem before i rebuilt and none after applying this fix.I cant accurately describe the location but you may come accross the tech update if you scour the internet or ask some savy mechanic who,s rebuilt them by the hundreds(and theres lots of them dudes).Oh yeah...the other fix that accompanies this problem is an updated seal for the reverse servo piston.Apparently its designed with a small lip that wipes the bore clean after aplication of reverse.For some reason this is neccassary for prolonged life ....i guess thats the logic.
Old Jan 28, 2003 | 04:17 AM
Opera House Works
became standard on the reverse servo in the 5R55E. While drilling the feed hole out is interesting, it was done to overcome the large leakage of the standard round O ring. This would just mask the real problem. The cold flow viscosity of the fluid has also been greatly improved in the last couple of years. If the transmission shifted when it was new, it doesn't need to be drilled out.
Old Feb 4, 2003 | 09:04 PM
steverowe's Avatar
steverowe
Angry 1998 Explorer Transmission - reverse shift delay
I just got the POS back from the tranny shop today. The transmission was on its way to being toast. Among other things, overdrive was shot.
Old Feb 5, 2003 | 01:26 AM
jon42's Avatar
jon42
Got any usable planeteries you wanna sell?
Old Feb 5, 2003 | 07:30 PM
steverowe's Avatar
steverowe
They were shot.
Whoda thunk the transmission would go with less than 90k easy miles on it. Not me.
08bella
2004 - 2008 F150
Feb 10, 2017 03:08 PM
occupa
27
Feb 10, 2017 10:52 AM
stevenjf88
Oct 28, 2015 10:39 PM
StanleyZ
Jun 26, 2013 04:31 PM
neos37
Aerostar
Nov 6, 2008 09:13 PM
